I have 12 Summit Racing coupons for the PY family Christmas stockings! These are specifically numbered for single use. So if you decide to use one, please reply which number you used so another member doesn’t try to use the same number. Shared with the honor system in mind so please do not sell the codes on eBay. Also, in the Christmas spirit please only use one so others may have an opportunity to save some money. These expire on 12/31/24
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 12-25-2024 at 12:09 PM. |
| The Following 4 Users Say Thank You to grivera For This Useful Post: | ||
Two more:
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
Oh, you're 10 days too late or I jumped the gun 10 days ago! Would have saved a hundred bucks.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
Story of my life! Hopefully it will help others looking to buy some off season goodies.
Thank you very much for posting codes. I used Code # ZD07668814. Saved me $46.77. Thank you again. Charles
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
| The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
You’re awesome, I’m in need of an Ididit steering column and u joints, these coupons will definitely help. Merry Christmas.
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
| The Following User Says Thank You to *67firebird* For This Useful Post: | ||
Thank You! I used one from post 2, ending in 8810. That was quite a stocking stuffer surprise. $187 savings! Merry Christmas and Happy New Year!
| The Following User Says Thank You to Jay S For This Useful Post: | ||
just saved $72 just ordered Ididit Steering column and universal shaft kit. Thanks!
I used ZD01662821
Thank you. Saved some money to put decent mufflers on my 62. I used ZD07662829 which was the first of the two extra ones you posted.
| The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
I just used ZD09662825. Thanks grivera
| The Following User Says Thank You to cdrookie For This Useful Post: | ||
Very happy these are being put to good use- they expire today at midnight so please feel free to use another if you need to - don’t feel restricted to just one per person! Will
I tried to go through and use one more but unless I’m bad at typing it looks like they were all used. Just to save someone else some time trying them all.
Thank again.
Maybe others have used them and haven’t posted ?
Most likely yes. It’s always possible I was doing something wrong but I got the one to work the other day. Someone else can check me but I think I went through all of them.
Here’s one more- thought I would use it but ain’t gonna happen! In case there’s been an entry error with the ones not accounted for, it’s worth placing the order on the phone so the rep can assist. In some cases they will give you a courtesy 10% off if the issue can’t be resolved.
| The Following User Says Thank You to 67Lemons For This Useful Post: | ||
