44"vs 24" is a big difference, the bars going across at the bottom should support some of the sway.Im not looking to put this at max height just high enough for trans removal using a trans jack.I know amazon is kinda iffy but I was just using their pic for reference.Like mentioned before I've had a 4 post and also one of the quik jack .The 4 post was nice but took too much room and still had to jack it up to tire change.I want something I can drive over and raise car easy peisey.
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
