Old 02-24-2025, 12:25 PM
I added a pic of the retainer that prevents the switch from resetting on that style circled for clarification.
You have to pinch both sides together enough so it clears the housing to enable the reset.
In some cases with the pedal at rest, the switch post is in the middle of the travel slot, and will not be at the end of the slot.
In these cases, I suspect it would be important to not make the switch post travel into the operating range too much during install, or it may impact the operation/ final setting.
The switch has 2 contacts, so it will close the contact prior to WOT. Otherwise a simple on/off contact switch would be all that's needed.
I'm guessing that range is somewhere between the 1/2-3/4 range of throttle.
ID:	648000   Click image for larger version
Old 02-24-2025, 01:44 PM
steve's Avatar
steve steve is offline
I’m sorry the brown switch from Amazon does not have the indicated plastic tab on the side and does not function that way. Pinching does not work.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
The Following User Says Thank You to steve For This Useful Post:
Old 02-24-2025, 02:15 PM
Kenth's Avatar
Kenth Kenth is offline
What does the slider looks like when you pull it to the end position? (both sides).
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-24-2025, 02:50 PM
steve's Avatar
Smooth. But like I said it will not pull all the way to the end on one side. It goes from center to full forward (toward seats) It will not slide past center away from the seats (toward the firewall).
Old 02-24-2025, 05:11 PM
Kenth's Avatar
You will have to squeeze/pinch the slider as shown on my pic to pull the slider to the end, away from the seat.
The hooks on the slider inside the switch is what prevents the slider to be pulled "away from the seat" to the end of the slot.
I wish i could do this for you!!!!
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-24-2025, 05:26 PM
steve's Avatar
Ok thanks !
