Old 02-24-2025, 11:49 AM
Ok, I get it now, the F-body ones work in opposite direction of A-body, like attached pic.
The at-rest position is in the center of the switch travel slot. As you push the peddle, it moves away from the firewall.
Take a pic of it installed. If you are saying that it doesn't contact the switch until it's almost at WOT, either the bracket is bent, or the switch is installed backwards maybe?
Take a look at the pic. That is at-rest, and the switch actuator post is in the center of the switch.
  #62
Old 02-24-2025, 11:53 AM
I'd check the switch for continuity when pressed and released, like when throttle at idle and when floored.
The switch is just an on/off setup. 12 volts when pushed to floor which goes to solenoid inside tranny. In combination with the vacuum modulator and governor the tranny shifts.
GM didn't want the switch to work except when at full throttle basically. Relying on the vacuum and governor to handle shifts.
  #63
Old 02-24-2025, 11:56 AM
Kenth's Avatar
Kenth Kenth is online now
Originally Posted by steve View Post
Thanks for the help but no amount of pinching will allow the slider to move into the position shown in your pic with the blue arrows, and on this unit there is no triangular mark on the metal housing as in your pic with the red arrows.
You should be able to pinch the slider and pull it for reset.
ID:	647998   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #64
Old 02-24-2025, 12:25 PM
I added a pic of the retainer that prevents the switch from resetting on that style circled for clarification.
You have to pinch both sides together enough so it clears the housing to enable the reset.
In some cases with the pedal at rest, the switch post is in the middle of the travel slot, and will not be at the end of the slot.
In these cases, I suspect it would be important to not make the switch post travel into the operating range too much during install, or it may impact the operation/ final setting.
The switch has 2 contacts, so it will close the contact prior to WOT. Otherwise a simple on/off contact switch would be all that's needed.
I'm guessing that range is somewhere between the 1/2-3/4 range of throttle.
ID:	648000   Click image for larger version
  #65
Old 02-24-2025, 01:43 PM
steve's Avatar
steve steve is offline
You do see that in the picture of your switch there is a small raised tab area on the side that looks like it is intended as release when pinched. My brown one does not have that and does it not operate that way.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
  #66
Old 02-24-2025, 01:44 PM
steve's Avatar
I’m sorry the brown switch from Amazon does not have the indicated plastic tab on the side and does not function that way. Pinching does not work.
The Following User Says Thank You to steve For This Useful Post:
  #67
Old 02-24-2025, 02:15 PM
Kenth's Avatar
What does the slider looks like when you pull it to the end position? (both sides).
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #68
Old 02-24-2025, 02:50 PM
steve's Avatar
Smooth. But like I said it will not pull all the way to the end on one side. It goes from center to full forward (toward seats) It will not slide past center away from the seats (toward the firewall).
  #69
Old 02-24-2025, 05:11 PM
Kenth's Avatar
You will have to squeeze/pinch the slider as shown on my pic to pull the slider to the end, away from the seat.
The hooks on the slider inside the switch is what prevents the slider to be pulled "away from the seat" to the end of the slot.
I wish i could do this for you!!!!
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #70
Old 02-24-2025, 05:26 PM
steve's Avatar
Ok thanks !
  #71
Old 02-25-2025, 02:20 AM
dataway's Avatar
dataway dataway is offline
I gotta admit I'm totally confused too. I think I have a spare in the shop that I'm going to have to take a look at. I had no idea there was any adjustment, I thought it was an on-off switch ... and I always wondered why it was so complicate for an on-off switch
Recently while still doing final shakedown of the car after being off the road for 40 years I did notice the kick-down required the pedal to the floor, which it never did before .. but of course I pulled the current switch off a 2bbl lemans and never "adjusted" anything, and probably worked it back and forth numerous times before installing it in the GTO.
  #72
Old 02-25-2025, 06:05 AM
Don't worry Ive seen people do that quite a bit, grabbing the switch and moving it back and forth not realizing they just moved the adjustment.
Just a fyi I have several nos gm switches still in the box and they come from gm with the switch in the full back position so that when it's installed it's ready for the pedal to be pushed to set the switch adjustment. You can tell if someone has opened the box and played with the switch because I have one that someone has pulled the adjustment out of it. I had to reset it and put it back in the box
https://youtu.be/XqEydRRRwqE
  #73
Old 02-27-2025, 11:40 PM
MYGOAT's Avatar
MYGOAT MYGOAT is offline
Here's a YouTube video showing how to reset kick-down switch. may not be the right way but seems to work for him.
https://www.youtube.com/shorts/373NC2MCd1M
The Following User Says Thank You to MYGOAT For This Useful Post:
  #74
Old 02-28-2025, 04:23 AM
dataway's Avatar
MYGOAT, excellent, thank you very much. That explains it perfect.
And exactly what I did before I installed mine, I put the VOM on it, worked it all the way up and got continuity and figured all was good, and installed it. Now I can see why mine is not kicking down when it should.
After all this time, still learning stuff about this car. Wonder how many people realize these switches are adjustable.
