Old 03-16-2025, 06:24 PM
Goatboyjohnny Goatboyjohnny is online now
Default Wheel disc paint
Can anyone confirm what color the painted areas are on my 66 wheel disc? I've always thought they were a satin black, but this pretty nice set I have might be otherwise.. The ring around the center cap definitely seems to be black, but the rest of the areas seem to be almost a dark argent, or just very faded. Thanks to anyone that can help.
Johnny
Old 03-16-2025, 06:27 PM
propuckstopper propuckstopper is offline
Johnny
I think you will be perfectly safe and correct using SEM Trim Black.
Old 03-16-2025, 06:28 PM
That's what I have always thought too, but wanted to make sure. Thank you sir!
Old 03-16-2025, 06:46 PM
Jeff Hamlin's Avatar
It's almost a Slate Grey/Silver, not black like the center cap ring.
Old 03-16-2025, 06:48 PM
Old 03-16-2025, 06:52 PM
Well dang!.. Thanks Jeff!!! Is it Metallic? Those both look great on those cars.. love both the whitewall and redline look.
Old 03-16-2025, 07:28 PM
It is/was Metallic.
Old 03-16-2025, 10:49 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 1966 Custom Wheel Disc
I have two NOS that definitely have the Black ring in the center and a type of flat gray around the 6 openings.
Any condition used Wheel Disc after 60 years will have lost it’s Factory Original paint finish from the elements, washing and waxing.
This flat gray was also used on the 1967 Custom disc.
ID:	649021   Click image for larger version
ID:	649022   Click image for larger version
ID:	649024   Click image for larger version
ID:	649025   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 03-16-2025, 11:07 PM
60sstuff's Avatar
Default 1967 Custom Wheel Disc - NOS
Seems to have the same flat gray paint around the 6 openings.
ID:	649028   Click image for larger version
ID:	649029   Click image for larger version
ID:	649030   Click image for larger version
Old 03-17-2025, 02:02 AM
Looks like I have some more color matching to do. Thanks guys, truly are the best!
Old 03-17-2025, 08:02 AM
Andre's Avatar
Andre Andre is offline
I bought a set of NOS ones for my 1966 GTO about 10 years ago. As others have pointed out, it is NOT black. Its not silver either. It might be the charcoal used on rally 2 wheels. But here is the challenge.-The manufacturer of these wheel covers used some type of mask and applied the paint very thin resulting in an opaque finish with the stainless area below the paint making it look quite different than if you painted it on a different colored surface. When I restored the '67 spinners that Chris shows, I used the charcoal rally 2 paint. It looked too dark, but I was using a spray can. Over time, it lightened up to look more like the NOS one that Chris posted. Whether or not this is the correct color for the 66 cap, I don't know
The Following User Says Thank You to Andre For This Useful Post:
Old 03-17-2025, 08:15 AM
Thanks for the input Andre. I was thinking that it might be the charcoal rally II color. I have a formula for that color, I think thats where I'll start, and tint as needed from there.
The Following User Says Thank You to Goatboyjohnny For This Useful Post:
Old 03-18-2025, 07:29 AM
Andre's Avatar
Lay it down thin. Use an airbrush if you have one.
