Old 04-22-2025, 10:33 AM
78w72 78w72 is offline
LOL...
Old 12-01-2025, 06:23 PM
burd burd is offline
Originally Posted by 78w72 View Post
LOL...
Yes it’s shiny crap. Good enough to sell at Dayton.
I go to auto body paint store to get the good stuff mixed up.
Oer is prom SEM GARBAGE
Old 12-02-2025, 10:46 AM
Originally Posted by jonesyboy View Post
Any recommendations if you have a decent amount of surface rust to deal with under the trim rings? I have a '71 Formula 400 with a build sheet that said it came factory with the Honeycomb wheels. Would like to keep it factory, but the wheels I have need a more serious restoration than what is described here (although, very helpful!!). Any advice from anyone that knows or has done this work? Can the Honeycomb insert be removed and then epoxied back into place? I don't want to "experiment" with any of my wheels, if possible. Thanks!!
If its just rust around the edges where trim rings go that can probably be cleaned up unless it is under the endura HC area too. But probably not a good idea to attempt removing the honeycomb then epoxy back in place, for all that work and unknown amount of rust underneath it would be cheaper & easier to find some nice used wheels and restore them. Doing it as HPP shows or countless others have done is perfectly fine & will last for a very long time.
I did these with the OER magnesium wheel paint & SEM primer that according to one guy that bashes anyone that uses it is "CL gravel driveway resto" LOL! Been holding up great for about 10 years now and looks like the day I did them.
Give it a rest, gets real tiring when you keep bashing anyone who doesnt do what you do... just because paints are in a spray can doesnt mean they arent good quality, you can have dupont, PPG or any brand paint put in a spray can at auto paint stores, Ive had it done for touch ups or smaller parts. Plenty of body shops use all kinds of SEM products... they are sold at auto body paint suppliers too.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 01-03-2026, 12:46 PM
rildon rildon is offline
Default 72 Grand Prix Honeycombs
Your Honeycomb project looks great to me. Looking for a little advice on mine if you don’t mind. I have some on a 72 GP that are honestly in pretty good condition with just some minor blemishes. They may have been touched up before. I really just want to give them a fresh topcoat using the OER Magnesium. What type of sanding and primer should I be doing and using. I can post pics later.
Thanks!!
If it’s just rust around the edges where trim rings go that can probably be cleaned up unless it is under the endura HC area too. But probably not a good idea to attempt removing the honeycomb then epoxy back in place, for all that work and unknown amount of rust underneath it would be cheaper & easier to find some nice used wheels and restore them. Doing it as HPP shows or countless others have done is perfectly fine & will last for a very long time.
