Plugs were run just cruising ,not wot .all plugs looked the same except #1 seems a little rich.Yes I did swap plugs and got same results,also changed #1 intake valve seal.What are your thoughts?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
I must add ,new engine with 150 miles still running Driven break in oil.Leak down test 4% ,compression 210psi all cylinders.Plugs are autolite 3923,I just put in some ngk fr5 to test
Have you done the accel/decel runs to seat rings? Just keep it a bit fat and slow timing down for break in. Don't set the tune on kill for the first 1k miles. Just make sure it's not lean or oil fouling, aka keep it between the ditches for awhile. Use 93 octane or higher.
What is the best plug gap
| The Following User Says Thank You to 64speed For This Useful Post: | ||
Are you "Joes455" now?
This thread on spark plug reading is "Joes455" thread.
Yours is another thread?
Oh gotcha I’m sorry missed it. I just scrolled down to the bottom and saw the last comment
468/TKO600 Ford thru bolt equipped 64 Tempest Custom. Custom Nocturne Blue with black interior. Last edited by 64speed; 04-23-2025 at 07:47 AM. |
