Old 04-24-2025, 08:30 AM
1967gto1 1967gto1 is offline
Default 67 gto pcv tube
I am going back to the stock air cleaner/vent tube set up and I have a question about this tube. The end that goes down into the valve cover goes in pretty far. This tube was in my box of parts when I bought the car several years ago, so I have not used it before. The end of the tube is a little nicked up where maybe it hit a spring. I want to cut some of the tube off so it's not so close to where it can hit a spring. Is this a good idea or not? Thoughts?
Old 04-24-2025, 01:30 PM
Kenth's Avatar
Kenth Kenth is offline
I think the engineers at Pontiac figured the length of the tube out.
Just use it as intended.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-24-2025, 02:06 PM
Good point. The tube would have to move a lot inside the valve cover to hit something. It is strange however that the tube does have some gouge marks near the end of it.
Old 04-24-2025, 02:15 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I’ve owned several of the #616 A.I.R 67’s and know of others and never experienced any problem with that tube.
It was engineered that way for a reason.
ID:	650732   Click image for larger version
ID:	650733   Click image for larger version
ID:	650734   Click image for larger version
ID:	650735   Click image for larger version
Old 04-24-2025, 02:19 PM
The reason I asked 60sstuff was because of the gouge marks. Just being cautious.
Name:	vent tube 2.jpg
Old 04-24-2025, 03:55 PM
242177P's Avatar
242177P 242177P is offline
Tube was designed to reside inside a baffle. Unless you've
got no drippers, contact with a valve spring is impossible.
The Following User Says Thank You to 242177P For This Useful Post:
Old 04-25-2025, 10:17 AM
So "242177P" there is supposed to be a baffle mounted inside the valve cover for the tube to go down into. All I have on my valve cover is the rubber grommet. I was just concerned that the tube could move around a little bit inside the valve cover. I just have the factory chrome plated steel covers.
Old 04-25-2025, 02:10 PM
242177P's Avatar
The dripper/baffle looked like this. HTH.
Old 04-28-2025, 09:36 AM
Okay thanks "242177P". I don't have that dripper/baffle setup on my engine.
