Old 04-13-2025, 10:37 AM
Carl S Carl S is offline
Default 65 Full Size Power Trunk Picture?
I am hoping someone can help me out with a picture that shows how the 65 vacuum trunk power unit (the actuator that mounts to the trunk latch) is mounted. If I remember right it mounts at an angle, not horizontal. Does someone have one in a 65 Catalina, GP, Bonneville etc and would be willing to post a couple of pictures? My friend is wanting to install one in his 65.
Thanks!
1966 Strato Chief 427 4 Speed 45,000 miles
1966 Grande Parisienne 396 4 Speed Factory Air (1 of 23)
Old 04-27-2025, 06:07 PM
BILL BOWMAN1's Avatar
Mounts on driver side.
Old 04-28-2025, 01:36 AM
Thank you, that helps a lot. Do the 2 bolts that hold the vacuum unit on go just through the latch mounting plate to the vacuum unit, or do they also involve the latch itself? I'm assuming the bolts just go through the latch plate only but I'd like to be certain.
If you have a picture of where they go through the latch mounting plate as well that would be great but this already helps..
Old 04-28-2025, 09:19 AM
Keith Seymore's Avatar
Just as an aside - my '63 came with the vacuum remote trunk release.
I could get it to work if I put a hand held vacuum pump on the port directly, but the engine could not generate enough vacuum to get it to pop.
I ended up retrofitting a more modern (circa 1968) electric system so that I could have the functionality.
K
'63 LeMans Convertible
'63 Grand Prix
Old 04-28-2025, 06:11 PM
Couple more pics.
ID:	650946   Click image for larger version
Old 04-29-2025, 08:04 AM
Perfect! Thank you so much Bill.
Old 04-30-2025, 09:44 PM
imposter's Avatar
imposter imposter is offline
where does the release button go in the interior
Old 05-02-2025, 02:19 AM
Heybuck's Avatar
Heybuck Heybuck is offline
Inside the glove box. Left hand side, just below the switch for the glove box light.
To laugh at men of sense is the privilege of fools.
