Old 05-02-2025, 10:34 AM
JLMounce JLMounce is offline
Default Those With Mini-Tubs...Would You Do it Again?
Question is the title. I'm considering doing mini-tubs on my 69 as it's in need of more tire with the new engine I built.
It was never something I intended to do because of issues relating to the back seat, the amount of surgery it actually is on good factory metal in my car.
If you've done this, or had it done, what were the pitfalls, if any that you ran into? Hidden costs or issues you didn't know about?
My back seat rarely ever gets used, so losing it isn't the end of the world if that would become necessary.
Any experience on this would be helpful. Thanks in advance!
-Jason
1969 Pontiac Firebird
Old 05-02-2025, 11:01 AM
Gator67's Avatar
Gator67 Gator67 is offline
I've done two second gen's, no regrets. Both are pro-touring type cars with aftermarket 4-link suspension and 335 18 sized tires. Not sure how wide you can go on a first gen without interference with original leaf springs. Both cars have back seats--just modified the rear seat frame and had new the covers made/modified by an upholsterer for a finished look. On one I modified the armrest panels to fit, on the other I just stretched the armrest panel to fit. The former looks better, but was a lot more work and might not hold up over time.
Old 05-02-2025, 11:38 AM
69 Model year cars can fit a 335 with leafs if they have offset shackles and a notched fuel tank. Some lip rolling may be necessary at that width. I'd probably convert to a SpeedTech torque arm link setup in the rear at that point.
I would probably run a Corvette C6 GS wheel size as it has a plethora of tires available for it. 19x12 with a 325 section width. That would give me 50mm more contact patch in width and would increase roll-out patch from the 27" overall height compared to my current 275/35/18's with a 26" height. Both would significantly help traction without the need for a drag radial.
-Jason
Old 05-02-2025, 01:59 PM
65madgoat's Avatar
ZERO regrets on a first gen. A must. Get on it! Been waiting for your to do it. And no need for 335s. I'd stick with 315s in back since you are only so wide up front. 18x9 front and 18x11 rear is ideal in that case.
265 front
315 rear
And yes SpeedTech torque arms kits are the ticket these days as their kits put power to the ground the best.
Old 05-02-2025, 03:28 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Same here. Zero regrets using the DSE version.
I also kept the backseat, aesthetics only. Not much work to "notch" corners and such.
Rear tires 390 / 45 x 15
Section is nearly 15 inches
Tread 12.5 inches
Wheels 15 x 12" (Budnik Arrowheads of course)
https://www.summitracing.com/parts/M...kaAo2oEALw_wcB
You can "stretch" the width of the tubs slightly during installation without harm.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 05-02-2025, 09:05 PM
Appreciate the experiences.
madgoat how are you fitting a 9" wheel with a 265 up front? I have a 245 on an 8.5 right now and do rub slightly.
-Jason
Old 05-02-2025, 09:22 PM
65madgoat's Avatar
Stock subframe but wilwood discs and 5" backspacing on 9" rims and no rubbing. Have over 5° positive caster and -1.5 camber.
Old 05-02-2025, 10:50 PM
How low is the front end? That's part of my issue. By car is very low, it limits how far out I can stick the wheel.
Current alignment is at -1 camber, +6.5* caster 1/16th toe in.
-Jason
Old 05-02-2025, 10:56 PM
65madgoat's Avatar
I mean I'd have to check fender height but I feel sits right with coilovers. 265/35 tires with fender about 1/3 over the top of the sidewall if that helps
Old 05-02-2025, 11:20 PM
Oh yeah, my car is functionally lower than that...by a lot.
I can put a 255 on this wheel though, I just like a little bit of stretch on the tire to help turn in feel.
-Jason
Old 05-02-2025, 11:46 PM
65madgoat's Avatar
Yeah that is low. I gave up going a half inch lower so I can drive everywhere with no issues.
Old 05-02-2025, 11:53 PM
I actually don't scrape everywhere I go. I don't even really have to worry about how I drive the car. This angle makes it look worse than it is because the car is straddling a fairly sharp bend in my driveway.
The front wheels rub the large inner fender washer at full lock, that's about it.
-Jason
