Old 05-20-2025, 08:47 AM
Default Wondering If This Is Correct?
https://www.ebay.com/itm/37596895464...Bk9SR-bY1tvdZQ
I was under the impression that 3.08 wasn’t produced anymore. Thoughts??
Old 05-20-2025, 10:53 AM
JLMounce JLMounce is offline
Easy way to find out would be to call up Quick Performance directly and verify that's a real item.
-Jason
1969 Pontiac Firebird
Old 05-20-2025, 10:57 AM
call 'em up & ask them, easy clue is how many splines on the pinion.
have purchase eaton style clone carriers from Quick Performance before & installed, worked fine, no problems. Not real keen on cheap Chinese R&P's & bearings.
Old 05-20-2025, 11:05 AM
Yes. The offshore parts are a concern. Is there still a US made bearing-Timpken? An upgrade to a 3.08 would be nice but a growling-howling rear end is a hard NO.
The Following User Says Thank You to PontiacHO For This Useful Post:
Old 05-20-2025, 11:48 AM
Meant to ask Pinion Head… what spline count defines the BOP 8.2 rear end. 28 pinion splines?
Old 05-20-2025, 12:52 PM
Up to 68 they where 31 spline, 69 and up then there 28.is what I recall.
Old 05-20-2025, 07:16 PM
Timpken would be chinese. Look for Timken. If not the any Made in Japan bearing. Used originals might have to do. Redline "Shockproof" lube for vest results.
Old 05-21-2025, 02:47 AM
Kenth's Avatar
Kenth Kenth is offline
You need to check the FACTS.
JMHO
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-21-2025, 07:49 AM
I did not say they where facts .
Skidmark's Avatar
Skidmark Skidmark is offline
JMHO
Since you seem to know the answer to the OP's
Question, what is it? He's requesting help and I'm curious as well.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 05-21-2025, 08:08 AM
Keith Seymore's Avatar
Ha! Too funny - I'm sitting at the McDonalds about a mile from their shop, waiting for them to open.
I'm picking up my 9" axle today.
K
'63 LeMans Convertible
'63 Grand Prix
Old 05-21-2025, 08:39 AM
Chevy 8.2 10 bol has a 25 spline pinion & pinion flange
Buick & Pontiac 8.2 10 bolts will have 27 spline pinion flange
There have been those that adapted 8.2 Chevy gearsets into Pontiac 8.2 10 bolt housings by machining a bushing that was then driven into the pinion seal bore. Then the chevy pinion seal could be used. Not something I've messed with, & am no longer assembling early gray iron 8.2's of either style.
Bearings & races are globaly sourced. Federal Mogul began sourcing the production of its bearings & races from all over the world near 30 years ago. For example there was tons of small bearing production utilizing very high quality steel out of the eastern block after the Soviet Union fell. For r/e bearings, races, & seals I typically buy locally, then examine, & if needed try another source.
Old 05-21-2025, 05:04 PM
I asked the eBay seller what the spline count was on the pinion, and they responded that it was a 27 spline
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 05-21-2025, 05:16 PM
K
I used them for parts to rebuild the 10 bolt in my wife's former 71 Chevelle. They were easy to deal with and pricing was good. They did initially send a wrong axle that was mis-labeled, but they made it right with overnight shipping and return of the mis-labeled part.
I already had/have a Moser 12 bolt in my bird, so I'm not in need of any parts, but I'd definitely use them again based on my experience.
-Jason
Old 05-21-2025, 06:12 PM
Thanks. They won’t sell just the ring and pinion. Strange. Could be a blessing in disguise.
Old 05-24-2025, 12:46 PM
Does this look like an 8.5 10 bolt?
Old 05-24-2025, 01:52 PM
I was talking about the axle splines.
Old 05-24-2025, 04:51 PM
Kenth's Avatar
Still wrong.
Fact is all Buick and Pontiac 8.2" had 28 spline axle shafts.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 05-25-2025, 08:26 PM
Rar_421 Rar_421 is offline
At one time Yukon made a kit to use Chevy gears in the 8.2,not sure if it's still available
https://youtu.be/QvGsrxQNass?si=5potSKXFQColc6TW
Old 05-26-2025, 06:34 AM
gman005's Avatar
gman005 gman005 is offline
I have the Yukon kit in my 72.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
