Old 06-10-2025, 01:32 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default 455 value
What's a 1973 455 from a grand prix with 96k miles worth?
Old 06-10-2025, 02:03 PM
scott70's Avatar
scott70 scott70 is online now
If not blown up and no cracks 750-800? Buying a block, crank, caps , timing cover. The rest isn’t worth much.
Old 06-10-2025, 02:30 PM
JLMounce JLMounce is offline
I've seen blocks for sale locally asking around $1200 for a 455 in rebuildable condition. I don't know if they are getting those amounts or not.
-Jason
1969 Pontiac Firebird
Old 06-10-2025, 02:58 PM
bdk1976 bdk1976 is offline
Need more info on condition - complete and running std bore with good compression vs locked up rusted out .060 shortblock makes a huge difference.
Old 06-10-2025, 03:34 PM
grandam1979 grandam1979 is online now
Stock 96,000 mile engine that runs ok $1500+ is what I would ask. My2¢
Old 06-10-2025, 03:53 PM
SD455DJ SD455DJ is offline
I sold 2 '72 455's that ran, air cleaner to oil pan (YC Codes), for $1500.00 each a couple years ago. Both sold quickly, so maybe a little undervalued...
Dennis
Old 06-10-2025, 04:37 PM
GTOLiam's Avatar
GTOLiam GTOLiam is offline
$400 if I'm trying to sell it...... $1000 if I'm trying to buy it
"Hammer to fit, paint to match"
Old 06-10-2025, 08:09 PM
Half-Inch Stud Half-Inch Stud is online now
Cast rods vs steel rods, cast vs forged pistoons..
Old 06-10-2025, 08:19 PM
RocktimusPryme's Avatar
Every once in a while I will see one pop up for $500 ish. Im never fast enough to get to it first so that's probably a little underpriced.
Realistically I would say 800 if you want to get out of it pretty quickly, less if you really want it moved, and 1000 or more if you are willing to sit on it.
Like others have said if you can show it has original pistons and decent bored with no overbore with a scope or something that would help.
Old 06-11-2025, 11:42 AM
KS circutguy's Avatar
The 1973 400 blocks were much weaker in the main webs than earlier blocks.
I split one in that area with 300hp nitrous hit.
Just a heads up, for performance applications I'd much rather use 1972 or earlier piece.
Old 06-11-2025, 12:02 PM
Kenth's Avatar
Kenth Kenth is offline
1967-74 and W72 XX 400 blocks are just fine.
It is the 1975 and later #500xxx blocks that are weaker.
BTW, this thread is about 455´s value.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 3 Users Say Thank You to Kenth For This Useful Post:
Old 06-11-2025, 04:54 PM
Thank You
