Old 06-11-2025, 06:06 PM
trix15's Avatar
trix15 trix15 is offline
Default Help Identifying A Carrier
The following carrier came with my car when I bought it. I was told that it was a posi carrier for a GTO. I have attached pictures wondering if anyone can tell me what they think that I have here. There are 37 teeth on the ring gear (never came with a pinion). Ratio says 37 / 11 were for a 336, but the stamp on the ring says 37 / 9 which would be a 411, which were not a standard option for a 1969 GTO. I guess my questions are - is this actually a posi carrier? What series is it? Would I be able to reuse my 355 ring and pinion that are presently on my open carrier?
Thanks,
Blair
ID:	652775   Click image for larger version
ID:	652776   Click image for larger version
ID:	652777   Click image for larger version
ID:	652778   Click image for larger version
Old 06-11-2025, 06:07 PM
trix15's Avatar
A few more pictures
ID:	652780   Click image for larger version
Old 06-11-2025, 08:30 PM
Sirrotica's Avatar
The 4.11 ratio is stamped GM so it never came in a Pontiac A body, likely a chevelle set of gears. Chevy did make a 37-9 set for chevelles.
'Ol Pinionhead (member here https://forums.maxperformanceinc.com...r.php?u=141176)
is the member that will be able to tell you exactly what you're looking at, as well as what it fits. Probably one of the top guys that know every GM rear axle, and parts of that era just from looking at it.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-11-2025, 09:13 PM
Held for Ransom's Avatar
Or, member monzaz (Jim). His forum... http://forum.jdrace.com/
So long, farewell.
Old 06-21-2025, 03:22 PM
KentGBR KentGBR is offline
I have an identical looking carrier (LSD w/ 3.55 gears) in my 1967 Firebird. Was under the impression that it is a 3-series, cone style, 4-pinion Safe-T-Track unit but would love to know for certain. It was definitely added at some point, as the car originally had a 3.36 open axle (XG), per PHS docs.
Old 07-01-2025, 11:06 AM
trix15's Avatar
Here is the reply I got from Jim on his site.
The Following User Says Thank You to trix15 For This Useful Post:
