Old 07-02-2025, 01:14 PM
nickdee62 nickdee62 is offline
Default 1964 GP Questions ???
I took on a 64 grand prix without doing much research. I had no idea I would have so much trouble finding parts. I need help finding dropped front spindles.. Did any GM cars interchange with the 64?I can't even find stock spindles!!!
Old 07-02-2025, 03:16 PM
misterp266's Avatar
I don’t believe that anyone ever made dropped spindles for it. As for stock stuff, Franks in AZ is your best bet.
https://frankspontiacparts.com/usedp...iacpartsp2.htm
" Darksiders Rule "
Old 07-02-2025, 04:21 PM
tom s tom s is offline
Frank is in CA for outside of Palm Springs,29 Palms as I remember.Tom
Old 07-02-2025, 04:48 PM
misterp266's Avatar
Ya, CA, got it mixed up with Steve in AZ. Probably not gonna visit in person anyway.
Your other best choice is Steve Barcak in AZ. He’s a member here, has tons of cars but not really in the parts business.
Lots of knowledge here, ask questions, you’ll get good answers.
" Darksiders Rule "
Old 07-09-2025, 12:46 PM
Default 64 grand prix spindles???
Does anyone know what front spindles interchange with the 64 grand prix? It looks like bonneville and impala will work.
Old 07-09-2025, 03:04 PM
Keith Seymore's Avatar
Why not just cut the front coils?
Saves all this angst coming up with unicorn spindles.
K
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 07-09-2025, 04:11 PM
Mario64's Avatar
Mario64 Mario64 is offline
have you considered lowering springs? eaton spring company or betts springs make custom springs. a lot better ride than cutting coils off of a factory spring.
they will probably need to know the factory ride height and and what the weight is and what height you are trying to lower to.
good luck.
mario64
p.s.: i used aldan coil overs on my 64 GP to lower mine just enough to see it isn't stock height.
Old 07-14-2025, 11:59 AM
Thanks for the info so far. Besides spindles, any info on ANY interchangeability would be greatly appreciated.
Old 07-14-2025, 01:17 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Stock spindle interchange for sure between 63-64 all full-size Pontiac B body models overall 61-64 Pontiac B body front suspension interchanges I probably have some spindles.. Catalina Bonneville grand Prix all the same in that department . No drop spindles exist I ever heard of. There are disc brake conversions that use the stock drum spindles
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 07-14-2025, 06:59 PM
694.1 694.1 is offline
59-64 Pontiac. Ambidextrous.
(Great excuse to use that word
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 07-14-2025, 07:28 PM
webfoot's Avatar
webfoot webfoot is offline
I put QA1 adjustable coilovers on my 62 - you can get them with springs rated for a BBC. All I had to do to get them to fit was drill out the nutserts in the lower A-arm.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-17-2025, 12:04 PM
Great info, thanks so much! How about some transmission suggestions. Going with the 389, would like a 4 speed automatic. Anything good bolt right up?
Old 07-17-2025, 12:55 PM
Mario64's Avatar
a 2004R should fit in there. you will need the bop version. it should be built with billet internals and it will take the torque. it wont be cheap. i put one behind my 500 ci caddy, replaced the t-400. just needed a different slip yoke for the drive shaft. also use a lockup convertor. i used a b&m auto lockup switch. it can be set for different speeds. my caddy runs at 1770 rpms and 77 mph. perfect for freeway. 2.73 to 1 rear.
mario64
Old 07-17-2025, 04:06 PM
mgarblik mgarblik is offline
If you are using the original 389 that came in the car, make sure the block is drilled and tapped for an engine mounted starter. That was a transition year and I do not think all 389's had engine mounted starters or even a starter pad on the block for that matter. That will make a transmission change much more complicated, not impossible.
Old 07-17-2025, 04:15 PM
Mario64's Avatar
that is a very good point. who knows what has been done to these cars by all the different owners.
i was lucky when i bought my 64 grand prix. one of the previous owners had installed a t-400 and he half assed the neutral safety switch on the shifter.
i replaced it with a shiftworks shifter in the correct shift pattern.
mario64
