in my mind I was envisioning a battery conditioner / Isolater between the alternator and the battery. |
I have a 535 Pontiac with 11:1 and terminator x with cnp and use the cam and crank signals from the holley dual sync and it always starts right up no issue. I am using the XS D2700 battery listed as 1140cca with Powermaster 9410 starter. It cranks around 200rpm. I do notice in the data logs during the first half second or so of cranking that rpm does show syncing though.
| The Following User Says Thank You to Dlaw455 For This Useful Post: | ||
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Great thread, looking like 1500ca Lithium is the threshold on power and 200rpm a known good cranking rpm minimum for insta-starts. 110rpm for both me and R 70 Judge = embarrassing efi starts.
BTW, the Antigravity techs say Lithium isn't tested in CCA so only CA numbers are real for Lithium. I'm doing 2 cars soon with Lithium swaps so I'll add data too but so far I think we're seeing the value of the battery power and cranking rpm for aftermarket Efi. No one was really talking about this so big thumbs up to this thread.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
I suspect they don't spec cca as that is a lithium battery's weak point. Probably not a real concern for us folks here though. My xs 2700d CA is rated at 1300 though. Half the cost of the Li but a lot heavier. Good things its in the trunk though. Lol
Here is my 2 cents worth. I was in the market for a Lithium battery, so I spoke to Tony the owner of Sick Goat about it. He said they had friends who tried many different brands with mixed result in the longevity department. But found that the brand called "Voltphreaks" lasted the longest they had found. So, I purchased a Voltphreaks 16-volt Lithium battery and charger...you need a specific lithium charger to charge them! Something to remember. Total with charger was $1200 a lot of money but I was after weight saving and they only weigh 8.25 Lbs. This was back in 2019 and it's still going strong. Never loses a charge even when my car sat with the engine out for a year it didn't need a charge! My engine is a 525 cube 14-1 compression 900+ horsepower carbureted engine. It cranks right up every time and to say the least I'm super happy! It even has an on off button that you can shut the battery down when not in use. It also has a sensor that will shut it down say if you left the lights on so you will still have enough power to start the engine. I've never had an issue but there is one thing the Voltphreaks website is no longer up, and I don't know if the company is still around, I hope so because I would definitely buy another one if and when this one dies.
| The Following User Says Thank You to alloy indian For This Useful Post: | ||
Just got the ATX-30HD 970ca for my GN, no car terminals included and their little mounting block is M6 so nothing fits.
I need the posts with threaded top mount and the Shuriken SAE20 are 10mm too long of screw (short screw one). R70 Judge, you buy the Anti terminals AG-TA-1?
That looks nice, I like the extension off the posts for other power needs.
They said the same thing, ATX-30HD is still considered a motorcycle battery, though it's 970ca and their best seller because autos are buying. Charge $10 more, throw in terminals, big deal, it's $560 already and this battery is clearly the one cars that don't need over 1000ca are buying for the weight and cranking power vs motorcycles who clearly don't need 1000ca. I'm gonna test this in my GN first and log, then try in the GTO and see if this is all we need to fire fast.
| The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
So early results...
Napa 800cca battery, 190rpm cranking, mostly 3+ sec cranks and many 5+ sec. Antigravity ATX-30hd battery, 140rpm cranking but in the 4x I've started it, every time starts within 1 sec???? I'll post logs soon, don't have them on my phone but there might be something else at play here beyond my pay grade. ATX-30hd was 13.3 volts fresh from Antigravity (they are the only ones that sell this battery, all other batteries vendors can sell). Maybe the starting and cranking volts are helping other components fire up faster and cranking rpm is one strong variable but not the end all.
Volts at battery terminal while cranking might help interpret.
We're cables the same for both? |
| The Following User Says Thank You to Shiny For This Useful Post: | ||
Agreed. Voltage drop is also a good thing to look at
Exact same everything, battery swap done within minutes of each other logs.
Napa 800cca = 11.4v cranking average Antigravity 30hd = 12.2v cranking average The cranking volts is almost a full volt higher so maybe that's a big piece of this vs just battery cranking amps in general. I will say this, if this does the same thing in my GN then saving $500 vs the Antigravity Group 24 battery makes me happy since I wasn't pumped about a $1050 battery.
After a bunch more starts today that are within 1-2 seconds tops, this is legit and cured my issue. I'd get lucky and have 1-10 starts like this with the 850cca (probably 950ca) battery and a bunch of embarrassing ones but not even 1 on 10 with the Antigravity so far was even close to bend sad, the are all awesome or normal Efi starting you'd expect.
Now holding down this little gremlin is turning into a chore, got on McMaster Carr a 5/16 -18 x 8" bolt coming for the factory hold down and threaded hole.
| The Following 2 Users Say Thank You to GOAT8U2 For This Useful Post: | ||
im of no help in the lithium battery department, but i am running 16 volt system with my holley efi, a converted 12si alternator, and a 16 volt turbo start battery. more is def better in my experience. I was running it with the carb and magnafuel 500 pump for better starting this car will never go back to 12 volt. i may be able to get a cranking rpm number for you next time its off the storage lift.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
#38
I'm sure you are happy it's working better now!
I expected higher voltage to generate higher cranking rpm, but seems not for you... Quote:
Can anyone explain why a battery delivering higher voltage to the same motor wouldn't make it spin faster? Is this because the Antigravity battery can't deliver as much current, even at the higher voltage? In other words, is the torque of a starter motor current-limited, independent of voltage? Mike |
#39
CCA's are VERY misleading on AGM's, compared to a lead-acid. In my experiences, a quality AGM (not the AutoZone/O'Reilly "AGM") with about 400CCA will outperform a lead-acid of 1000CCA. I've used the XS Power S925 and S975 with several larger inch street/strip motors, and they were more than powerful enough (and less than half the weight of a lead-acid). About the same cost as most lead-acids now, too. Lithium looks interesting, but I'm happy with the AGMs at this point.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
#40
Update...
Completed the full Antigravity install, got a new battery tray and then drilled through it for the Antigravity tray to be solid. Antigravity ATX-30hd 970ca (7.25lbs) 7-25 AG-TA-1 terminals (M6) AG-BT-LC-30 battery tray Hold down bracket bolt OEM = 5/16-18 x 8 OEM battery tray GMK433230068 5/16-18 SS bolts into car body AG-BT-LC-30 holder for ATX-30HD battery Ag holder screws into OEM tray 1/4-20 x 1 Vgate terminals (M4, M5, 1/2" nut)
