Old 08-07-2025, 10:57 PM
indiangiver 68's Avatar
indiangiver 68 indiangiver 68 is offline
Default 1962 1963 super duty 4 barrel air cleaner
Looking for information and pictures of factory race cars air cleaners. Trying to find this for a running display 421 super duty 3 barrel engine.
Old 08-07-2025, 11:02 PM
Pictures
ID:	655350   Click image for larger version
Old 08-07-2025, 11:26 PM
tom s tom s is offline
For display you could run one of these.Tom
Old 08-08-2025, 10:40 PM
pont406's Avatar
pont406 pont406 is offline
Thumbs up
The single 4 bbl SD air cleaner were large diameter and used a 16 x 5 inch filter, they were primarily used by NASCAR stock cars, they are rare and hard to find today ,here's a few pics
Name:	61 sd 389 bonnie 2.jpg
ID:	655378   Click image for larger version
Name:	62 sd 389 motor.jpg
ID:	655379   Click image for larger version
Name:	62 nascar sd engine.jpg
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
The Following 2 Users Say Thank You to pont406 For This Useful Post:
Old 08-07-2025, 11:23 PM
The SD ACs on the dual quads won’t fit the 3 bbl.The 3 bbl has the large top and was only used on Super Speedways and I’m sure used a custom NASCAR approved AC.The 4 bbl NASCAR Carter AFBs were used on non Super Speedway cars.I run a pair of them on my Bathtub.I know Pete’s book has the number for the 63 version.When I get home I can give you the number.Off hand I think 4473.Tom
Old 08-10-2025, 08:04 AM
Perfect
That is exactly what I was looking for.
Now I need to find or build one.
Also is the engine pictured a 61?
Old 08-10-2025, 08:12 PM
pont406's Avatar
Originally Posted by indiangiver 68 View Post
Perfect
Yes a 61
Old 08-10-2025, 08:22 PM
pont406's Avatar
Thumbs up
here's a couple pics of mine to show the back of it better, a friend has some made a few years ago, not sure if he can get anymore done or not, i'll ask him
ID:	655473   Click image for larger version
The Following User Says Thank You to pont406 For This Useful Post:
Old 08-11-2025, 09:17 PM
pont406's Avatar
Thumbs up
He doesn't have anymore made, they were made from early 63/65 Buick Riviera or late 50's Cadillac air cleaners, you have to cut them horizonally and add around 3 inches in height to the outer shell, (cutting the holes in the rear) the carb opening may need modified as well to fit larger carb , air filter size is a rare 16 x 5, i have a damaged spare filter that could be used for mockup, or could stack a couple of standard air filters that would work if height is right
Old 08-10-2025, 08:40 AM
It’s either a 61 or early 62 with 306 heads.Tom
Old 08-14-2025, 10:18 AM
Thank you for the additional pictures and information. I'd love to buy one done, but maybe I have to build it.
