Old 08-10-2025, 08:12 PM
pont406's Avatar
pont406 pont406 is offline
Originally Posted by indiangiver 68 View Post
Perfect
That is exactly what I was looking for.
Now I need to find or build one.
Also is the engine pictured a 61?
Yes a 61
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 08-10-2025, 08:22 PM
pont406's Avatar
Thumbs up
here's a couple pics of mine to show the back of it better, a friend has some made a few years ago, not sure if he can get anymore done or not, i'll ask him
ID:	655473   Click image for larger version
The Following User Says Thank You to pont406 For This Useful Post:
Old 08-11-2025, 09:17 PM
pont406's Avatar
Thumbs up
He doesn't have anymore made, they were made from early 63/65 Buick Riviera or late 50's Cadillac air cleaners, you have to cut them horizonally and add around 3 inches in height to the outer shell, (cutting the holes in the rear) the carb opening may need modified as well to fit larger carb , air filter size is a rare 16 x 5, i have a damaged spare filter that could be used for mockup, or could stack a couple of standard air filters that would work if height is right
