Old 08-23-2025, 06:39 PM
gtobird's Avatar
gtobird gtobird is offline
Default Pressing on rear axle bearings 68 Wagon
It's been about 5 years since I last installed rear axle bearings. I've got the axles out of the car, stripped and clean ready to press on the bearings. This is a vanilla stock 68 Pontiac 10 bolt rearend with pressed on bearings. I can't remember......... Do you generally put some sort of lube on the bearings and retainer rings before pressing them on, or leave them dry?
Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 08-23-2025, 07:21 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I use a trace of lube to press on the bearings but loctite on the retaining ring.
I once had a retainer (and bearing) lose its press fit and the axle walked out of the housing. The axle splines did a nice job of grinding off material from the inside of the axle tube as the axle migrated out. This was on a '68 Firebird.
Old 08-23-2025, 07:40 PM
gtobird's Avatar
Yikes! must have been ugly losing an axle that way. Which locktite are you using? Blue, Red or the 609 Green that is made for bearings.
