Looks like it has usual Vintage Air control knob functions just adapted to a slide lever configuration.
The weird part is that when I look at the panel for 68 Firebird on the VA site, the control positions are reversed. The panel on the VA site has Hot on the Left and Cold on the right, for instance. This is not how my panel looks, but it IS how it functions. I have yet to find a picture of VA 3 lever panel with the control positions like this one. I think it may be easier to just see if i can order the panel that corresponds to how my levers work rather than trying to reconfig the levers on this one.
Is it possible that the cal was not done correctly? I have a Classic Auto Air system, and it basically works the same: enter cal mode, and put sliders in the appropriate position as called out in the cal procedure, to remember the resistance setting on the 10k ohm sliders.
Consider starting there. Maybe the installer taught it wrong? Interesting enough, your current control panel is how mine is set up: cold left, hot right. Dash vent position is all the way left. My system took the factory air control head and converted it to fly by wire, so it looks factory. If you were feeling adventurous, you could possibly reverse the slide resistors upside down so that the max/min resistance sides are swapped. Then your functionality would likely match your controls.
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 09-17-2025 at 04:07 AM. |
Thanks! I'll give the resistors a try. Honestly, it works fine, the OCD in me just cant stand the mislabelling.
Fer sure!
"...ridge reamer and ring compressor? Do they have tools like that?" |
