My vin number says the car was an 81 turbo trans am from the factory. Someone put a 350 in it when the turbo died and tried to clone a formula. I now have a Pontiac 400 block in the car. See in the pic how far the shaker sits to one side? And that’s with the element mounted as far the other way it will go as well. I’ve seen a few pics online of cars with the shaker off by the same amount. Is it possible cars that were originally 301 turbo cars were set up a little different to cause this ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers.... |
301t cars & engine bays are the same as non 301t cars, same mounts & all. The crooked off center shakers are usually related to bent frames in the cross member area that allows the whole engine to sit to one side... not saying thats your issue but Ive seen it on quite a few cars over the years that werent 301t cars originally.
I put a Shaker hood on my 81 with a 400-it is centered
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Mine too!
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
I have paperwork from a frame/body shop stating the frame is not bent but I suppose anything can be possible. It’s just that it’s off by several inches and the body looks straight to the eye. Not to mention there should be other things off but nothing looks wrong. I would also think the nose would be farther off center than the cowl area and that doesn’t seem the case here as well.
Shoot some pictures of the Shaker base in the scoop, maybe one for a SBC?
Also what intake, carb & air cleaner base does the car have?
My 81 has a Performer intake a little low in rear but centered. My 78 has a T2 and is centered. So like he asked intake, base.
Sorry for the delay. Here are pics. The “carb stud” is 29.125” to the drivers fender edge and 28.00” from the passenger side. I guess the fenders are out of wack at least. Possible the whole front clip is pushed over but you can’t tell from looking at the outside of the car and my body panels are not off by that much. The intake is a Northwind. Holley terminator and gen IV
Im not familiar with the aftermarket drop base air cleaner set ups, or how the shaker plate is attached to it, maybe thats related?
But the front clip or subframe/core support can be off side to side, was that measured when put back together? Can measure it now to see if its off, subframe to rocker panels as well as an X measurement from top rear fender mount bolts to top core support fender bolts, should be equal. |
If alls good, re rivet the base on
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Southern Hamtramck Institute of Technology , Alumni Put some 8” flakes and BFG’s on dude!, like everyone does🙄 Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers. 1978 YEE 1995 Q45 #whoremembers |
