Old 11-01-2025, 05:03 PM
tempest1964's Avatar
Yeah, apparently some of the early ones came with a throttle pedal bracket with an arm for a solid linkage rod and an arm for a spring return. I’m attaching a photo of the unit. I may try to modify the original for my dual quad setup. In the attached photo you can see the arm with the rubber grommet. This is where the carburetor linkage rod attached. The other arm, with the 3 holes is where the pedal return spring attached.
