#1701
Pulled the engine out and took it to Jim Pickett for some upgrades and to find out why there was a serious drop in oil pressure.
#1702
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
| The Following 9 Users Say Thank You to 71GP76TA For This Useful Post: | ||
#1704
Did 100 mile country cruise this morning down over the Ohio river from Kentucky to Indiana and back home . Enjoyed some coffee and a podcast along the way .
| The Following 4 Users Say Thank You to locomotivebreath For This Useful Post: | ||
#1705
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
#1706
Quick spin in the 73 Formula and parked it outside under cover.
DragStarLeMans |
| The Following 8 Users Say Thank You to Drag Star Le Mans For This Useful Post: | ||
#1707
I swapped out the rear lower control arms on the 1971 Catalina Freeway Enforcer so I could remount the 7/8" rear bar the PO had removed and swapped out the arms with ones that didn't have mounting holes for the mounting brackets for the rear Bar. The new arms were a NOS Kit that was intended for the recall on the 91-96 Caprice's with the 9C1 Police package or Taxi cabs. They were breaking the rear control arms at the 4 smaller holes used to mount the rear sway bar mounting brackets inside the C section of the arms. The upgraded arms use 2 thru bolts to mount the Bar thru the control arms upper surface. They use spacer around the bolts, and small plates that overlap the lower control arms. Comparing the 2 control arms, the only functional difference I could find was the distance between the front and rear bushings was 1mm longer hole center to hole center on the new arms. This was probably the easiest control arm swap I have ever done but as stated the PO had swapped them out about 25-30 years ago, and the car has less than 35K original miles on it, even if it is a rust belt car.
And while I was there I took the time to clean up the large 12" finned rear drums, even though you can not see them with the wheels installed.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
| The Following 5 Users Say Thank You to camerjeff For This Useful Post: | ||
#1708
[QUOTE=71GP76TA;6592667]Went to a Car-B-Que at a friends house yesterday.
dang...i would never leave lol
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#1709
#1710
Look's like a good time there.
#1711
Got my wiring diagram in hand, multimeter and labels and heading back out into the garage to start making heads or tails on the wiring mess in my 67 GTO. Also waiting on my remanufactured gauges for the dash pod.
My money talks to me-it usually says goodbye! |
| The Following 2 Users Say Thank You to carcrazy For This Useful Post: | ||
#1712
If you got some holiday funds early, an American Autowire upgrade harness is a migraine saver.
https://www.summitracing.com/parts/a.../gto/year/1967 I used one on my 71; top notch. No chasing corroded contacts and bad splices. |
#1713
| The Following 3 Users Say Thank You to 71GP76TA For This Useful Post: | ||
#1714
Spent a little time on the wiring (long way to go) but decided to go ahead and wash and cleanup my 62.
| The Following 7 Users Say Thank You to carcrazy For This Useful Post: | ||
#1715
Carcrazy, that is one beautiful 62. I love it!!!
#1716
It is an original 425A, 4 speed car.....lots of fun!
#1717
Change my power steering brackets on goldie today I was having problems with belt slipping. I removed six brackets
and replaced two with better alignment |
#1718
pic of the six I removed and pic of the 3 replaced on the engine.
| The Following 2 Users Say Thank You to post toastie For This Useful Post: | ||
#1719
at long last...
| The Following 6 Users Say Thank You to Scarebird For This Useful Post: | ||
#1720
After an extended cold spell, it hit 51 degrees outside today so my little space heater added enough to take a chance with 2K epoxy and aerosol black. Same heater is helping them cure in my deluxe drying rack.
