Old 11-20-2025, 11:24 AM
JLBIII JLBIII is offline
Pulled the engine out and took it to Jim Pickett for some upgrades and to find out why there was a serious drop in oil pressure.
The Following 3 Users Say Thank You to JLBIII For This Useful Post:
  #1702
Old 11-20-2025, 12:30 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Originally Posted by 7t4mula View Post
That’s awesome that she felt confident in driving the Bird! My wife has said once or twice she’s not sure if she trusts herself to drive ours now when I finish it… knows it will be a handful. And it’s only been 23 years, has a 4spd now!
We just had that discussion on the dimmer switch as I was installing the carpet. She’d forgotten about that!
I always preface the drive with, "Remember, you do not have power brakes, ABS or traction control on this car."
The Following 2 Users Say Thank You to srmmmm For This Useful Post:
  #1703
Old 11-23-2025, 02:43 PM
Went to a Car-B-Que at a friends house yesterday.
The Following 9 Users Say Thank You to 71GP76TA For This Useful Post:
  #1704
Old 11-23-2025, 02:57 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Did 100 mile country cruise this morning down over the Ohio river from Kentucky to Indiana and back home . Enjoyed some coffee and a podcast along the way .
When I wore a younger man's clothes
The Following 4 Users Say Thank You to locomotivebreath For This Useful Post:
  #1705
Old 11-23-2025, 06:25 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Attachment 661174
I see you drove your SD. Looks like a lot of nice cars showed up.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
  #1706
Old 11-23-2025, 10:34 PM
Drag Star Le Mans's Avatar
Quick spin in the 73 Formula and parked it outside under cover.
ID:	661185   Click image for larger version
DragStarLeMans
The Following 8 Users Say Thank You to Drag Star Le Mans For This Useful Post:
  #1707
Old 11-24-2025, 08:26 AM
camerjeff camerjeff is online now
I swapped out the rear lower control arms on the 1971 Catalina Freeway Enforcer so I could remount the 7/8" rear bar the PO had removed and swapped out the arms with ones that didn't have mounting holes for the mounting brackets for the rear Bar. The new arms were a NOS Kit that was intended for the recall on the 91-96 Caprice's with the 9C1 Police package or Taxi cabs. They were breaking the rear control arms at the 4 smaller holes used to mount the rear sway bar mounting brackets inside the C section of the arms. The upgraded arms use 2 thru bolts to mount the Bar thru the control arms upper surface. They use spacer around the bolts, and small plates that overlap the lower control arms. Comparing the 2 control arms, the only functional difference I could find was the distance between the front and rear bushings was 1mm longer hole center to hole center on the new arms. This was probably the easiest control arm swap I have ever done but as stated the PO had swapped them out about 25-30 years ago, and the car has less than 35K original miles on it, even if it is a rust belt car.
And while I was there I took the time to clean up the large 12" finned rear drums, even though you can not see them with the wheels installed.
Name:	arm comparision side.jpg
ID:	661192   Click image for larger version
Name:	arm comparision bottom.jpg
ID:	661193   Click image for larger version
Name:	rear bar installed.jpg
ID:	661194   Click image for larger version
Name:	rear bar installed hardware.jpg
ID:	661195   Click image for larger version
Name:	71 enforcer rear brake drums.jpg
The Following 5 Users Say Thank You to camerjeff For This Useful Post:
  #1708
Old 11-24-2025, 12:33 PM
[QUOTE=71GP76TA;6592667]Went to a Car-B-Que at a friends house yesterday.
dang...i would never leave lol
Old 11-24-2025, 01:14 PM
jhein's Avatar
jhein jhein is offline
Attachment 661174
That's awesome
  #1710
Old 11-24-2025, 01:27 PM
Look's like a good time there.
  #1711
Old 11-24-2025, 01:32 PM
carcrazy carcrazy is offline
Got my wiring diagram in hand, multimeter and labels and heading back out into the garage to start making heads or tails on the wiring mess in my 67 GTO. Also waiting on my remanufactured gauges for the dash pod.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1712
Old 11-24-2025, 02:16 PM
If you got some holiday funds early, an American Autowire upgrade harness is a migraine saver.
https://www.summitracing.com/parts/a.../gto/year/1967
I used one on my 71; top notch. No chasing corroded contacts and bad splices.
  #1713
Old 11-24-2025, 08:57 PM
Yep.. It was the only one there..
The Following 3 Users Say Thank You to 71GP76TA For This Useful Post:
  #1714
Old 11-24-2025, 11:28 PM
Spent a little time on the wiring (long way to go) but decided to go ahead and wash and cleanup my 62.
Name:	1962 Pontiac Grand Prix.jpg
The Following 7 Users Say Thank You to carcrazy For This Useful Post:
  #1715
Old 11-25-2025, 08:23 PM
Maurice Hood Maurice Hood is offline
Carcrazy, that is one beautiful 62. I love it!!!
  #1716
Old 11-25-2025, 11:49 PM
It is an original 425A, 4 speed car.....lots of fun!
  #1717
Old 11-30-2025, 10:05 PM
post toastie's Avatar
Change my power steering brackets on goldie today I was having problems with belt slipping. I removed six brackets
and replaced two with better alignment
  #1718
Old 12-02-2025, 05:39 PM
pic of the six I removed and pic of the 3 replaced on the engine.
ID:	661603   Click image for larger version
ID:	661605   Click image for larger version
The Following 2 Users Say Thank You to post toastie For This Useful Post:
  #1719
Old 12-05-2025, 03:25 PM
Default Back in Black.
at long last...
Name:	PT plate plate.jpg
The Following 6 Users Say Thank You to Scarebird For This Useful Post:
  #1720
Old 12-10-2025, 10:24 PM
Shiny Shiny is offline
After an extended cold spell, it hit 51 degrees outside today so my little space heater added enough to take a chance with 2K epoxy and aerosol black. Same heater is helping them cure in my deluxe drying rack.
The Following 4 Users Say Thank You to Shiny For This Useful Post:
