| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Can anyone help with decoding the following billing history? I am having trouble finding any reference to the options
PHS?
Zone 23, Dealer 11 = Zone 23 is San Francisco zone; dealer 11 Moore Buick-Pontiac-GMC Truck, PO Box 276, Los Gatos CA
Invoice date 6/29/1966 Model 24217 = GTO 2 dr hardtop coupe Z = Fremont assembly KK = Reef Turquoise Metallic 220 = dark Turquoise interior Box 34-2 = Radio Push button & Manual Antenna Box 41-4 = Lamp, Parking Brake Box 42-1 = Lamp underhood Box 43-1 = Seat Belts Custom front and rear Box 44-8 = Inst Panel rally guage cluster and tach Box 46-1 = RPO P01 wheel disc deluxe Box 53-2 = Glass soft ray Winshield only Box 61-6 = Smog (per 60sstuff, below) Box 62-1 = Ride and Handling package Box 70- C and 71-C = 7.75x14 red stripe Box 74-K = 3.55 axle (per 60sstuff, below) Box 75-W and 76-W = WW engine, Man Trans with AIR, 4 bbl carb Box 77-W = wide ratio trans Box 78-4 = manual 4 speed 8838 and 9912 are the trunk and ignition key codes. Armed with those a locksmith can make new keys.
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 12-04-2025 at 06:04 PM. |
| The Following 2 Users Say Thank You to Keith Seymore For This Useful Post: | ||
Box 616 is A.I.R. (Smog).
C C is Redline tires. K = 3.55 axle W = wide ratio Last edited by 60sstuff; 12-04-2025 at 05:56 PM. |
| The Following User Says Thank You to 60sstuff For This Useful Post: | ||
That IS the PHS. The billing history card (invoice) is what PHS decodes to create the packet.
You have to have a build sheet (or list of codes, like from the Eric White book) to decode. Although - I'm not sure how one gets the billing history card without getting the PHS decode. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 12-04-2025 at 06:18 PM. |
Here are two documents that pertain to a 1966 GTO.
Disregard the underlines as they pertain to my personal car. |
Great color combo ! And some good options.
Should have gotten at least one order form page like this with the BHC you have. |
616 =
Option 612 - Air Injection Reactor (AIR) Exhaust System Option 614 - Positive Crankcase Ventilation (PCV) System Both required in California 1966 with manual trans, went hand-in-hand with your WW (Cali) engine code. Air cleaner (if original) should have a pipe going from it to the valve cover. aka closed system |
FYI to keep the information correct for 1966 GTO’s.
Automatic with 4BBL. (code XE) also required A.I.R. (Smog) if sold New in California. The only GTO that did not require A.I.R. in ‘66 was the Automatic Tri-Power (code YR). |
Awesome, everyone, thank you for the help! While the car was originally a 4BBL model, it now has a TriPower.
Its claimed the motor has a YF stamp on the front passenger side of the block, not sure what vintage that is , also the manifold has a 093 stamped on it. I go and inspect tomorrow. |
No 612 air pump. Was 614 required on Cali YR engine - or did buyers choose that option ? |
since they used 093 heads with it. The heads are correct for 66 GTO , the manifolds start further below the 093 casting number. 389 block will have 3 freeze plugs per side. |
612 Exhaust Control 614 Crankcase Vent Exhaust control must be a GM blanket term , like with Chevy and their fancy plumbing into the exhaust ports. ![]() Great condition on that Buildsheet , Keith ! |
2 per side, right?
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
| The Following 2 Users Say Thank You to Singleton For This Useful Post: | ||
Yes , and thank you.
Not sure how I crossed that up . Photo memory needs a new roll of film in it. |
I list Moore as 23 011 in the '90s. For '67, 23 011 was Bernie Anderson Pontiac-Buick in Eureka CA.
| The Following 2 Users Say Thank You to WQ59B For This Useful Post: | ||
Thank you for all the help. I do have the accompanying PHS documents now it all makes sense.
Picked up the car yesterday after a very long day. Ill make another post with pictures once I get it unloaded. |
| The Following User Says Thank You to MPNX2 For This Useful Post: | ||
23-011 does not appear on the UltimateGTO dealer code list. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
| The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
Keith, if you are referring to me yes, I have the full PHS documents. I have some documents with the car that I still have to go through.
No - I was referring to WQ59B.
You will likely not have the dealer name unless you have the original window sticker or purchased a reproduction from PHS. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 12-06-2025 at 02:18 PM. |
