The breaker bar frame bump method is what I've done for years, and I recently went thru balancer R&R 3 times in a row, it works every time. And it doesn't take a lot of effort. Just get as much slack out of it as you can and it won't slip off.
A regular crank socket works pretty good for alignment, but some sockets are bigger/smaller, can make it a challenge. The tool works very well, and also has the larger end for install, which is a bonus. I have a Lisle seal & race driver kit that has a bunch of attachments, and used to use that, but that tool works much better. It's a dead-on fit and doesn't slide around. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
Removal of the seal has went well but when I removed the Balancer it has two grooves in it. Is that normal or an issue? If its an issue whats the solution.
1965 GTO all stock Thanks
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching 1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching 1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th) 1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching 1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching |
If I remember correctly, the rubber seal on cover doesn't slide back as far as the groove and your good. Mine was that way too.
Yours is probably fine but I'm curious how to verify the integrity of a 60-yr-old damper?
When I chased timing/idling issues I replaced the damper "just in case" the rubber and/or adhesion to metal was deteriorating and allowing slip. I never knew how to actually verify. Is there a way to verify? And if the groove is a problem, is there a thin sleeve that can be installed on the damper as a band-aid? Or would such a thing be impossible to install? |
| The Following User Says Thank You to Shiny For This Useful Post: | ||
They make a repair sleeve exactly as you mentioned, I used one years ago on a small block and worked perfectly, it was from Fel Pro.
1972 GTO |
| The Following User Says Thank You to 67Lemons For This Useful Post: | ||
Thanks for confirming the repair sleeve.
If it's already slipped it makes sense the timing mark would be off. What I'm asking is if there's a way to tell if the assembly has degraded to the point where it's not worth saving. For example, if it's close to slipping or if the rubber has degraded enough to lose "stiffness" and allow the timing mark to bounce around more than intended. We are told to replace old tires WELL before 50 years, so I'm curious how the rubber compound in these old dampers holds up and if there's a way to know that doesn't involve specialized equipment. I replaced mine because the timing was bouncing at idle. This was more likely because the mechanical advance wasn't stable but at the time I had a new damper and chose to just do it. |
A new balancer is cheap insurance and you won’t have to worry about it for a long while - I replace factory originals as SOP. Good idea to check/index the replacement.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
