Old 02-01-2026, 04:00 PM
Mike S's Avatar
Mike S Mike S is offline
Default Getting key buzzer working
Putting the 72 lemans back to stock. Trying to get the key reminder buzzer working. Traced everything out. I have a 3 pin plug where the buzzer plugs in. It is above and in front of the fuse box. One pin is ground, one battery positive and one is ground from the key switch.
My problem I cannot find the plug-in buzzer. Original one is long gone. I searched everywhere on the internet. Any ideas where to get one or a modern seatbelt alarm I can wire in?
Old 02-01-2026, 05:45 PM
Mr. G Mr. G is offline
I think there are some on E-bay.
Old 02-01-2026, 06:22 PM
johnta1 johnta1 is online now
The part that buzzes?
That is the horn relay I think? Does the horn work?
Old 02-01-2026, 07:43 PM
OG68 OG68 is offline
Horn Relay is the buzzer.
Relay should have four wires;
Red - Battery
Black - Horns
Green - Horn Switch
Pink - Key switch
The other side of the column key switch goes to the drivers door jamb switch
Old 02-01-2026, 09:49 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
That was a great question and I have the same issue with my 68 GTO.
I did buy a schematic for my GTO and did see that the horn relay and buzzer work together and I bought a new relay [ not installed yet]
and notice that the person before me said that the horn did not work they installed a new relay and looking at the AMES catalog a relay for an older GTO was used with someone's version of how to wire it [ not correctly] so now I know for sure the new 1968 relay is the way to go.
color me gone
Old 02-01-2026, 09:50 PM
1969GTO's Avatar
color me gone
Old 02-01-2026, 11:35 PM
Mike S's Avatar
Horn works perfectly. Horn relay is located under the dash near the headlight switch. It has 3 wires going to it. My research showed that in 72 they moved the horn relay to inside the car in this location. Can't find anything on the buzzer for 72.
There is a molded connector located above and in front of the fuse box with 3 wires, 12v, ground and ground from the key switch. My meter reads a ground with key in and door open. Clears when door shuts or key removed. It works perfectly. In search of the buzzer that plugs into this connector.
Only schematic I can find it 70-71 and does show it in the horn relay. Can't find schematic on 72. I bought the car from original owner in 1984 so am confident this is how the factory wired 72's
Old 02-02-2026, 06:43 AM
Schematic in 1972 Service Manual, also has a troubleshooting section for the buzzer. Section 12-4.
(Pics are probably too degraded from uploading here)
ID:	664489   Click image for larger version
Old 02-02-2026, 11:56 AM
This is from an original factory 72 service manual in color.
The pink wire to the horn relay is very faint.
The pink wire may have its own plug. Is there an open terminal on the horn relay?
Old 02-02-2026, 01:59 PM
burd burd is offline
NPD had the buzzers.
Old 02-02-2026, 03:03 PM
Shiny Shiny is offline
Do you find a pink wire coming off the connector on the steering column?
Originally Posted by Mike S View Post
Horn works perfectly. Horn relay is located under the dash near the headlight switch. It has 3 wires going to it. My research showed that in 72 they moved the horn relay to inside the car in this location. Can't find anything on the buzzer for 72. ...
A photo of this part might allow others with a 72 to compare/confirm
..There is a molded connector located above and in front of the fuse box with 3 wires, 12v, ground and ground from the key switch. My meter reads a ground with key in and door open. Clears when door shuts or key removed. It works perfectly. In search of the buzzer that plugs into this connector.
Same suggestion... a photo would help others understand what you are describing.
What wire colors enter this connector? Is nothing plugged into it? ???
Yes, it seems the pink wire did not copy but was there...
Seems a mismatch between the observations and both schematics. Could be:
- there's another terminal on the horn relay without a wire connected
- both schematics are wrong and there is indeed a separate buzzer on a 72
Definitely a confusing situation.
Does anyone else with a 72 have a horn relay under the dash and not on the firewall?
I added the missing pink wire (note that it is labeled) to johnta1's schematic.
Old 02-02-2026, 06:09 PM
indymanjoe's Avatar
maybe this can help?
ID:	664515   Click image for larger version
I am the Thread Killer!
indymanjoe's Avatar
more
ID:	664517   Click image for larger version
Old 02-02-2026, 10:17 PM
From what I'm reading on the WWW, the 72 Horn relay is a one year only part and not reproduced.
The buzzer is part of the relay itself as in previous years
Your's may have burned contacts. It's not a hard job to open one up and inspect.
Or you can adapt the wiring to an earlier 68-71 relay which will work fine.
From Indymanjoe's photo, it looks like the 12 volt power is a round tab protruding from the relay? Does that tab connect to a 12 volt power stud?
Old 02-02-2026, 11:10 PM
Mike S's Avatar
The first set of pics indyman posted is what I am talking about. The black wire is ground the orange is battery voltage, and the pink one comes from the key switch. I am looking for the blue part in his pictures Like I said everything works as it should, just missing the blue module. I am guessing it was unplugged early in it's life because it was annoying. Figures 72 is a one year only. Wonder if chevys are like this for 72.
I miss the 80's when you can walk thru a junk yard and get any part you wanted for these cars.
Old 02-02-2026, 11:36 PM
Mike S's Avatar
Found this thread. First schematic is what I am talking about (buzzer assembly).
https://forums.maxperformanceinc.com....php?p=5287438
Old 02-02-2026, 11:46 PM
Maybe adapt a buzzer from a different car or find a "universal 12V buzzer"?
Here's some parts on eBay that look similar:
https://ebay.us/m/SWDHy5
https://ebay.us/m/ILik5c
https://ebay.us/m/6rF6pn
Old 02-02-2026, 11:48 PM
Mike S's Avatar
Found one, but don't want it that bad.
https://oldsobsolete.com/products-pa...654/#gsc.tab=0
Old 02-03-2026, 06:29 AM
I didn't think of the seat belt buzzer, thought it was separate from the key buzzer.
Most people bypassed the seat belt interlock because it buzzed all the time.
The belt needed to be buckled to use the car.
That service bulletin probably showed how to bypass the seat belt system.
(didn't look at those pics in thread)
As was said earlier, use the horn relay?
If the horn works it must have a relay?
Old 02-03-2026, 06:31 AM
tigergto's Avatar
tigergto tigergto is offline
The buzzer is so annoying, I disconnected the one on my 71 GTO when I owned it.
The Following User Says Thank You to tigergto For This Useful Post:
