You guys did such a great job on my first request to ID a carb, I decided to let you show off again.
Pics attached Only numbers I can find on this one are on the bowl: 7008598 on the bottom of the bowl C-3 on the throttle arm side of the bowl Any guesses?
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
1958-63 Chevy 283.
each piece should have a casting number;
A casting number is cast into the part - as opposed to application numbers being roll stamped onto a part of the assembly. I believe all early (pre-1968) carbs had tags instead of stamped application numbers. I am not too sure if the 2bbl carbs had a tag attached to a main body screw or not - but I believe that's how I've seen most. People really in the know will be able to place with in a window of time based on the casting number(s) - as GM assigned them sequentially.
Many thanks for your responses
It's a SBC carb with the wrong throttle arm, wrong choke heat provision, broken air horn web, and smaller venturi's than the Pontiac early center carbs ('59-'65). I would trash it and find a suitable Pontiac carb. I have many if you're interested.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
It's a SBC carb and as such it has the CORRECT throttle arm, and choke heat provision.
I´m sure some Chevy enthusiast would love to have it. |
Yes, I knew it was not the correct carb for the Tripower set up it was on. Not trying to make this a functioning unit right now. Just doing an inventory on a bunch of stuff I’ve acquired over many years. I agree it might be useful to a Chevy enthusiast, so that’s probably where it will wind up.
