The Tomahawk is patterned from a improved Holley Dominator without the heat crossover so if those 2 things interest you then the Tomahawk is better plus its cleaner looking casting without the needless vac. ports
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following User Says Thank You to Formulas For This Useful Post: | ||
do you know where to get one? When I search it, the Hurricane comes up. I haven't seen any Tomahawks for sale. Bulter sells the Hurricane.
My Half AN Injun..... |
I guess the hurricane on Butler's site is considered a Tomahawk?
The origional product was developed and brought to market by Pacific Performance Racing and Ken named it the Tomahawk.
Professional Products was the manufacturing partner at the time and they listed the intake as part of the Hurricane product line. Next up...... "Speed Master does not make parts, they copy them." Paul K's comment and a discussion here: https://forums.maxperformanceinc.com...omahawk+intake Regarding the original Tomahawk intake brought to market by Ken Brewer. For marketing reasons, the port entrances 'as cast' were very small. Be prepared to open them up unless used on unported small ports with factory heads. Also some of the runners need work, they are not straight. Also for those who use a tall gasket you can go as tall as a SCE #128103 intake gasket without welding ( about a 2.3 tall port), BUT there is not much meat at the top with it for sealing. As mentioned, I suspect all the copy cat intakes of this design with different names are similar. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 02-09-2026 at 04:28 PM. |
I went with the speed master - hurricane manifold. Port alignment was horrible. My opinion is Port match Holly Street dominator and go with that. I used it anyhow car does run real strong though.
78 T/A 3,750lbs 1 5/8 headers 462 #16 D-ports 250ish CFM Lunati solid flat #40707 T-350 9" ATI, 3.90 gear 27" QTP on 8" weld stars Holley 750 vac- RPM ET- 11.3 @ 119.55 pump gas 9.5-1 comp |
| The Following User Says Thank You to BLK/RD462TA For This Useful Post: | ||
I had great luck with a Tomahawk. Got down to 11 flat with one.
But, SD had it in their hands at one time so the port match was nice. Plenum had some work too. |
A FWIW.....
The same situation on a Holley Street Dominator intake applies as on a Tomahawk/Hurricane intake if the ported cylinder heads have tall ports in use. Regarding the intake gasket port height to match, you can go as tall as a SCE #128103 intake gasket without welding ( about a 2.3 tall port), BUT there is not much meat at the top with it for sealing. The SCE catalog on page 203 states the 128103 gasket is 2.30" tall. https://www.scegaskets.com/wp-conten...25.V3__WEB.pdf This is not necessarly a recommendation here for that specific intake gasket. However I've used the particular gasket on all my ported cylinder heads over the years. Every SCE128103 I have purchased and used had a actual port height opening about 2.320" tall. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Ok, Thank you. Have you ever tried a Street Dominator?
Hey Troy, I can't find a Tomahawk anywhere, Is the hurricane the new Tomahawk now?
For interest, example of the need to weld a intake for tall ports:
https://hips.hearstapps.com/mtg-prod...75&format=webp The engine combo used 345 cfm CNC ported cylinder heads. Here the as cast Torker II intake manifold ports were too short for the tall CNC ports in the heads and required Tig-welding raised port tops in the intake, which needed to me machined flat and port-matched. .
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
I have a port match T2 on the 465 in my 1969 Firebird. It fits under the hood with a small drop base filter and made 580/600 on the dyno without any kind of spacer.
It sits on top of KRE 310cfm d ports. I don't think you need any more intake than this. My car with a 4l80 and 3.31 gears, it's heavily traction limited in first. I don't pine for torque anywhere with the combination.
Did you dyno it with the filter on or off? I was worried about with a drop base it would be restrictive. Those numbers are more then I'm going to see so that's good the here ..
Not yet, but I wished I originally went with the street Dom. Plus, there aren't any provisions for factory a/c brackets. Butler's site claim hurricane is good for 300 cfm heads. That's what sold me. I have their 290 d ports.
Ok thanks. Sounds like you figured it out though. So, this hurricane you bought from Butler? Or from speed master?
#38
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#39
#40
What carb are you using?
