Old 02-09-2026, 02:15 PM
Formulas's Avatar
Formulas Formulas is offline
The Tomahawk is patterned from a improved Holley Dominator without the heat crossover so if those 2 things interest you then the Tomahawk is better plus its cleaner looking casting without the needless vac. ports
Old 02-09-2026, 03:43 PM
charlie66's Avatar
do you know where to get one? When I search it, the Hurricane comes up. I haven't seen any Tomahawks for sale. Bulter sells the Hurricane.
My Half AN Injun.....
Old 02-09-2026, 03:57 PM
charlie66's Avatar
I guess the hurricane on Butler's site is considered a Tomahawk?
Old 02-09-2026, 04:15 PM
Steve C. Steve C. is offline
The origional product was developed and brought to market by Pacific Performance Racing and Ken named it the Tomahawk.
Professional Products was the manufacturing partner at the time and they listed the intake as part of the Hurricane product line.
Next up......
"Speed Master does not make parts, they copy them."
Paul K's comment and a discussion here:
https://forums.maxperformanceinc.com...omahawk+intake
Regarding the original Tomahawk intake brought to market by Ken Brewer.
For marketing reasons, the port entrances 'as cast' were very small. Be prepared to open them up unless used on unported small ports with factory heads. Also some of the runners need work, they are not straight.
Also for those who use a tall gasket you can go as tall as a SCE #128103 intake gasket without welding ( about a 2.3 tall port), BUT there is not much meat at the top with it for sealing.
As mentioned, I suspect all the copy cat intakes of this design with different names are similar.
Old information here:
Old 02-09-2026, 04:57 PM
BLK/RD462TA's Avatar
BLK/RD462TA BLK/RD462TA is offline
Send a message via AIM to BLK/RD462TA
I went with the speed master - hurricane manifold. Port alignment was horrible. My opinion is Port match Holly Street dominator and go with that. I used it anyhow car does run real strong though.
78 T/A 3,750lbs 1 5/8 headers
462 #16 D-ports 250ish CFM
Lunati solid flat #40707
T-350 9" ATI, 3.90 gear
27" QTP on 8" weld stars
Holley 750 vac- RPM
ET- 11.3 @ 119.55
pump gas 9.5-1 comp
The Following User Says Thank You to BLK/RD462TA For This Useful Post:
Old 02-09-2026, 05:52 PM
Dragncar Dragncar is offline
I had great luck with a Tomahawk. Got down to 11 flat with one.
But, SD had it in their hands at one time so the port match was nice. Plenum had some work too.
Old 02-09-2026, 06:04 PM
A FWIW.....
The same situation on a Holley Street Dominator intake applies as on a Tomahawk/Hurricane intake if the ported cylinder heads have tall ports in use.
Regarding the intake gasket port height to match, you can go as tall as a SCE #128103 intake gasket without welding ( about a 2.3 tall port), BUT there is not much meat at the top with it for sealing.
The SCE catalog on page 203 states the 128103 gasket is 2.30" tall.
https://www.scegaskets.com/wp-conten...25.V3__WEB.pdf
This is not necessarly a recommendation here for that specific intake gasket. However I've used the particular gasket on all my ported cylinder heads over the years.
Every SCE128103 I have purchased and used had a actual port height opening about 2.320" tall.
Old 02-09-2026, 06:06 PM
Gary H's Avatar
Gary H Gary H is offline
Originally Posted by charlie66 View Post
I'm curious to why you have them in that order. What is better about the Tomahawk and Torker II compared the Street Dominator? I'm asking because I already have the Street Dominator, but if it's worth buying the Tomahawk and shelfing the Street D I will. I can't find the Tomahawk all I come up with is the Hurricane. Who even sells them?
I wouldn't necessarily buy another intake to replace your Holley intake. As I said above, I doubt there would be a tenth of a second ET between the 3 of them. But if you were starting from scratch, the Tomahawk is supposedly a rough copy from a ported Holley intake. And, it doesn't have an exhaust crossover. Here in Florida, we try and keep the intake as cool as we can on street cars to avoid gas vaporization issues on carbureted cars. The lack of an exhaust crossover helps. If I were you though, I would keep the Holley and run it.
Old 02-09-2026, 06:18 PM
charlie66's Avatar
Ok, Thank you. Have you ever tried a Street Dominator?
Old 02-09-2026, 06:20 PM
charlie66's Avatar
Hey Troy, I can't find a Tomahawk anywhere, Is the hurricane the new Tomahawk now?
Old 02-09-2026, 06:21 PM
For interest, example of the need to weld a intake for tall ports:
https://hips.hearstapps.com/mtg-prod...75&format=webp
The engine combo used 345 cfm CNC ported cylinder heads.
Here the as cast Torker II intake manifold ports were too short for the tall CNC ports in the heads and required Tig-welding raised port tops in the intake, which needed to me machined flat and port-matched.
Old 02-09-2026, 06:25 PM
I have a port match T2 on the 465 in my 1969 Firebird. It fits under the hood with a small drop base filter and made 580/600 on the dyno without any kind of spacer.
It sits on top of KRE 310cfm d ports.
I don't think you need any more intake than this. My car with a 4l80 and 3.31 gears, it's heavily traction limited in first. I don't pine for torque anywhere with the combination.
-Jason
1969 Pontiac Firebird
Old 02-09-2026, 06:30 PM
charlie66's Avatar
Ok thanks, it doesn't really matter, I don't think for me with or without the cross over because my heads don't have an exhaust crossover. Do some street dominators have a hole drilled from the plenum into the cross over? I'm seeing ones that do in some pictures I'm looking at online. I have to look at mine it's been a while, and can the street dom be run without doing the mods to the front runners or is that something that really needs to be done?
Old 02-09-2026, 06:38 PM
charlie66's Avatar
So, stock Torker II just with port match, no other work to it?
Did you dyno it with the filter on or off? I was worried about with a drop base it would be restrictive. Those numbers are more then I'm going to see so that's good the here ..
Old 02-09-2026, 06:40 PM
charlie66's Avatar
One other question. Out of all 3 was one more responsive than another or were they all around the same?
Not yet, but I wished I originally went with the street Dom. Plus, there aren't any provisions for factory a/c brackets. Butler's site claim hurricane is good for 300 cfm heads. That's what sold me. I have their 290 d ports.
Holley 750 vac- RPM
ET- 11.3 @ 119.55
pump gas 9.5-1 comp
Old 02-09-2026, 06:53 PM
charlie66's Avatar
Ok thanks. Sounds like you figured it out though. So, this hurricane you bought from Butler? Or from speed master?
  #38
Old 02-09-2026, 06:58 PM
ta man ta man is offline
Originally Posted by PunchT37 View Post
I have a ported T2 intake at around 600 hp.
With a spacer?
  #39
Old 02-09-2026, 07:00 PM
Originally Posted by srmmmm View Post
If you have a few months in your schedule, I'd wait for the new Victor Jr coming this summer from Edelbrock. Single plane with stock height carburetor pad.
I'll be acquiring the port injection model when it becomes available and matching it up with the Edelbrock fuel rails and an Aces injection system for my 350/413 stroker.
Same height as the rpm intake..it is higher than stock.
  #40
Old 02-09-2026, 07:02 PM
What carb are you using?
