Old 02-25-2026, 12:09 PM
Shiny Shiny is offline
Originally Posted by Half-Inch Stud View Post
Hacksaw for cutting EXH pipes. Donta own a sawzall.
Muscle effort and the hard way are my choice, to get the exercise.
Understood and agree the exercise is good. But I can't keep a hacksaw moving in a straight line.
This:
I get that, but it's tough to get a good, square cut with a saw or wheel. .....
Tailpipes look like they are pointing at an angle downward, not sure you will be able to adjust them much, if at all.
You can probably get them a little higher, and then use a generic turn-down. You can't put a tip on and make it stay 'angled'....
The tail pipe stubs are actually pointed down a little. I started another thread about options to replace the tips I cut off:
https://forums.maxperformanceinc.com...errerid=160974
I've found the ratcheting ones are the best, and worth it if you do a number of exhaust work over time....
Good to know, thanks.... so buying a used one with worn out wheels is probably stupid.
I do all my exhausts on jack stands laying on my back, Pypes kits for years. I've tried all the cutters, and although the Lisle ones are 'better', but they flex if you tighten them down too hard. And same thing with once the blades start going, you will be 'cussin'....
I lightly clamp the pipes together with U clamps after marking a line across the joints. (in case it moves some during transport). Then take it up to a shop to get them welded. Any final fine-adjustments the shop can make as they weld.
I think I'd have to pay a shop to do this but my priority for now is to just get rid of the giant tips. The rest of the exhaust is in better shape than most of the car. It has glass packs that will have to go away some day so maybe then..
OE hangers are nice to use, there's considerable adjustment you can make with them (before welding mostly). Never 'load' the exhaust to get it where you want, over time it just rips the hangers off.
The approach has worked well for me over the years.
Personal tip: Always put an O2 bung on. You can plug it, but if you ever want to go efi, that part is done. Can be used for wide band tuning too.
All good input, thank you.
Mike
Old 02-25-2026, 12:16 PM
Yeah not a good idea to buy a used ratcheting type. Even if you replace the cutters the 'frame' may be loose/worn out. It's 'best' to start with a new one, but if it's cheap enough, and you can hold it in your hand and tell if it's good or not, than maybe.
Will take a look at the other thread, but thinking just some temporary generic turn-downs is your best bet.
If you switch over to a tail valance with cutouts, that would give you more options, especially in the future.
Old 02-25-2026, 12:19 PM
I was thinking. You can cut a slot across a pipe, push it together and weld it, to come up or correct off angles.
Just throwing that out there...
Old 02-25-2026, 12:37 PM
Yes, I suspect that's where I'm headed, thanks.
The stub doesn't have much clamp length because of the welded hanger so I will probably have to weld whatever I do to keep it from falling off. I will likely start with a clamp-on straight section so yes, slits would let me tilt it up or down. I'm literally headed out to take a measurement, will update the other thread.
And the valance with cutouts would be fun but that's a bigger project than I want right now. Priority is a mess on the quarter panel I've been putting off for 20 years.
Thanks again for the help!
Mike
