#1781
Had a mobile PDR guy come out to the house and fix a spot on the TA hood where someone tried closing the hood with tools still in engine bay. It came out perfect. I took pics before and after, but the ping wasn't visible with my cheap phone camera. So both pics looked the same.
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
#1782
Stripped my axle down. Preparing to put my new Auburn unit and 3.23 gear set in.
| The Following 3 Users Say Thank You to tempest1964 For This Useful Post: | ||
#1783
The Comp is now on Bring A Trailer and off to a slow start: https://bringatrailer.com/listing/19...c-firebird-28/
Visited 71GP76TA's previous employer to get some tires mounted, then used the Ventura to jump the Javelin to get it started for the first time.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#1784
Lemans running rough so i checked vacuum. gauge (direct manifold) bouncing fast between 5-22. Checked intial timing its 14. Starts every time. I've basically just been moving it in and out if the garage and maybe around the block since i got the TA a couple years ago. I need to check adjustments on the carb, do a compression check and leak down test. Thinking it could possible be head gasket I have mulitiple exhaust manifold leaks and one rocker thats not getting as much oil flow over it as the others as well
Really would like to pull the engine and focus on everything but the short block. Kinda inspect and go over to include engine paint a reinstall. Just don't feel that the engine has ever run to its true potential. I installed it about 15 yrs ago by my self (1st engine swap). I think i can do a better job now since i know a little more than I did back then.
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles Last edited by Skidmark; 03-16-2026 at 09:38 AM. |
| The Following User Says Thank You to Skidmark For This Useful Post: | ||
#1785
Could be head gasket, take a compression test.
It might be sticking valves or misfire also.
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
#1786
On my back, up under the dash of my 67 GTO working on the wiring.....making progress but slow going.
My money talks to me-it usually says goodbye! |
| The Following User Says Thank You to carcrazy For This Useful Post: | ||
#1787
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM |
| The Following User Says Thank You to salem1912 For This Useful Post: | ||
#1788
Separated the 2 parts of my valley pan to clean the inside...not really that dirty. I'll weld it back together when I get back to the barn. Then some nice DE1616.
| The Following User Says Thank You to gtospieg For This Useful Post: | ||
#1789
Moved it out of the rear half of my garage for the first time in a few months. I’m going to put some summer miles on it after I rejet the middle carb and change out the venturi cluster to achieve a leaner setup in the pursuit of better fuel efficiency.
Was moving cars around so I could put my ‘66 VW pickup into the rear garage to swap out the old 50hp 1600 for a 140hp 2276.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 8 Users Say Thank You to b-man For This Useful Post: | ||
#1790
That’s gonna wake up that VW truck for sure! Have fun!
********************************* The 1970 Pontiac Firebird Formula 400... Lean, mean, tire-scorching machine! |
| The Following User Says Thank You to 7t4mula For This Useful Post: | ||
#1791
Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
| The Following User Says Thank You to 71GP76TA For This Useful Post: | ||
#1792
#1793
#1794
When the guy was taking the ding out i told him it might have been there for 30 years or more. Lol. Best part was he only charged 75.00, but he got me for a grand to fix my daily driver. It had a 13" dent.
#1795
^^^ your VWs look amazing. my wife's from Rio .. I'm blown down every time I visit. they take their old VWs very serious down there ^^^
my motor went in very late last season so I never really got to take care of some pretty bedrock issues I was having till these past couple of weeks: - I was losing <all> power randomly .. and very often in the middle of traffic. ha. turned out to be the main hot connector on the cabin side of bulkhead connector wasnt locked into block. it would push out. - pertronix was not getting anywhere near enough Vs at "start" .. was having some really spectacular startup's. setup w/ relay now so getting fully battery Vs at run/start. night and day difference: car's starting easily, even in the cold and will snap your neck through the rpm's ; ) - wasnt getting more than 12.5v at alternator/battery ... new regulator today took care of that and battery's getting charged properly now. looking forward to digging into the carb and timing once we get some warm days! |
| The Following User Says Thank You to RAIIIJudge For This Useful Post: | ||
#1796
Valley pan welded back together and all paint removed...prime and paint next.
#1797
Picked up the new RA-IV repro intake from Reher-Morrison after they did some port match work. Hopefully this solves my cold temp vs high temp idle speed variation.
| The Following 5 Users Say Thank You to srmmmm For This Useful Post: | ||
#1798
Had the AFBs off my 63 Lemans gone through.Put them back on,all good,did not have to touch them.Fired up the 62 GP to go to a show in the AM.All good.Tom
| The Following 7 Users Say Thank You to tom s For This Useful Post: | ||
#1799
I switched from an old set of Mickey Thompson ET Street 30x12.5x15 bias ply tires to a Mickey Thompson radial slick 29.5x10.5x15. I drove it around a bit on the street and the difference in stability is night and day. The tail end isn’t dancing around like it used to.
A+ would recommend
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#1800
I noted a sizable 1/2" gap in the top above the frame rails when the top was up but did not address it. Today I examined it after removing the rear weatherstrip segment - the top hold down cable had broke at the rear eye. Evidently a stress location. My wife will return from the States after tax season so will order replacement from Ames. It lasted 30 years and many cycles since Dad and I installed it - a bit faded but still no rips (wood knocking!).
Weatherstrip seems pretty stiff, forgot how soft new ones are supposed to be - maybe a good soak in silicone will perk them up? |
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
