Old 04-03-2026, 03:16 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Originally Posted by Fastmonty View Post
Hey Team... love the comments. Those that don't know, I started with the full ColdCase radiator and fan kit, which I found insufficient. (The Cold Case 14" fans are actually 13") I started testing fans, and discovered that the Brushed 14" Spal, and 14" Proform Brushless have similar performance, and similar price point. I now have over 25 Shroud designs on my website, with new customer reviews weekly.
I will be coming out with a shroud for the Behemoth 14" Brushless SPAL, but as you know it's expensive. In this hobby, almost everything is "You get what you pay for". Finding that balance is the fun part.
As for the previously mentioned comment about the "Skid Plate" I designed for 64 to 72 GM A-Body's, it protects the Oil Pan, not the headers. It has saved my 69 GTO twice since installing it. Just did a video about the skid plate damage here; https://youtu.be/Q0DA63Rofos?si=c-vv8jUBctsGg_Ik
Any other questions, let me know on YouTube or through my website https://www.fastmontysgarage.com/
See ya!
Monty
You'll probably get a buyer for me once you do. Will you be making that 14" Brushless SPAL shroud for 70-81 Firebirds?
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Old 04-03-2026, 07:24 AM
krisr's Avatar
krisr krisr is offline
I'm running Mike's shroud on my 66 GTO and over here in the Australian climate we have some pretty hot summers. I ended up running the proform brushless fans with the proform PWM controller because the sniper won't output PWM. I just did a 400 mile round trip 2 weekends ago and the car was flawless! The car ran cool, looked cool. Awesome product!
The Following User Says Thank You to krisr For This Useful Post:
Old 04-03-2026, 09:37 AM
Originally Posted by R 70 Judge View Post
I have the Derale 16826 fan/shroud kit (dual 12” fans 4000cfm total) on my TA. Cold case radiator and a mezeire HD waterpump. I’m very happy with the setup. 14:1 on pump E85. The fans aren’t overly loud (to me anyway) and it will hold at 170*-180* max in 90+* weather on the street.
Seems to have gone up in price a bit Check out this page from Summit Racing https://www.summitracing.com/parts/d...iaaegj-npd_bwe
Yeah I went with the slightly larger shroud on my bird, the 18927, and run the 16837 on the GTO. Same fans in all 3 of those. I have the 16837 in the 442 as well.
Like I mentioned, the 535 is borderline, and am thinking if stepping up to the FMG 14" shroud and Proform fans.
Mike - Some reason I thought the bat wings would help cover the headers some, guess I should have looked harder! So the bat wings are more for stability/strength? Glad to see you on here!
Protecting the headers would have been a bonus, since right now, for me, headers are disposable items! Heheh!
Old 04-03-2026, 11:37 AM
Fastmonty's Avatar
Fastmonty Fastmonty is offline
I feel the same! My headers are border line trash as it is... way more important to protect the oil pans, as we'd have to fully remove the engine to fix that debacle, let alone rebuild it.
See ya!
The Following User Says Thank You to Fastmonty For This Useful Post:
Old 04-03-2026, 11:59 AM
Fastmonty's Avatar
It's plausible, here's a rendering and picture of my first try at the A Body Shroud, for a FrostBite FB304 radiator, it's beefy. This customer was ok with welding the corners, as my next design needs to avoid welding. The F Bird core is 1" narrower. So, keep that in mind for clearance on the sides of the radiator would grow 1/2" on either side.
Name:	FB304 Shroud Rendering Rev 2.1.jpg
ID:	667602 [ATTACH]Click image for larger version
Name:	Richs FrostBite FB304 WITH Shroud and Dual Spal 14 Brushless.jpg
Name:	Richs FrostBite FB304 and Shroud for Dual Spal 14 Brushless.jpg
Old 04-03-2026, 12:38 PM
Gator67's Avatar
Gator67 Gator67 is offline
Attachment 667602 [ATTACH]Attachment 667604[/ATTACH]
If I decide to switch from a factory style clutch fan & shroud in my 535ci 70 Formula to electric fans, this is what I’d go with.
Old 04-03-2026, 09:40 PM
See ya!
At roughly $1350 for a set of Doug's these days, every scrape is a total cringe! Heheh!
https://www.summitracing.com/parts/dou-d522?seid=srese1
I'm dropping back to the 1 7/8 ones, they fit better and tuck up better too.
So, just to comment, when you go to dual fans that are like 28a each to a 60a spike, you need a better alt, and you can only do like 140 MAYBE 160a alts on V belts. So it's serp and beefy alts. Soft starts are really the only way to go, and even so, you could probably draw 80a at idle. Or more.
Take that into account when you start doing to e-fans. This is the one thing where people fail and throw in the towel on with e-fans.
Old 04-04-2026, 12:01 PM
cmoc-bob cmoc-bob is offline
Monty - great YT channel, watch it all the time.
If you have time, any thoughts on using a late model (say 2500 or 3500 Chevy HD truck) fan blade assembly on a Hayden clutch fan ?
I would guess they'd pull plenty of air.
I saw you measured airflow when you tested the electric fans.
Slicker "test" would be the matching ECM controlled clutch fan.
But, more curious on airflow...........
Keep up the good work - we appreciate it.
Bob
Old 04-04-2026, 12:33 PM
73ta's Avatar
73ta 73ta is offline
Would like to see the cfm air flow of a stock shroud & a 19" 7 blade severe duty clutch fan.
The Following User Says Thank You to 73ta For This Useful Post:
Old 04-04-2026, 04:02 PM
This, this, and this. It would finally lay to rest a lot of discourse between e-fans and mechanical fans.
Old 04-05-2026, 01:16 PM
73ta's Avatar
My guess is that a mechanical when setup properly will outflow all of the electric fans.
