#81
Got this 400 tore down a little...
She put up a good fight, but I eventually won. Ended up cutting one of the long bolts that ran thru the WP & timing cover into the block that wouldn't break loose. Everything didnt slide off like I read tho. |
#82
Lol. Still struggling with these damn pictures. 🤬
Last post has a picture of my Q-Jet I just received back. Hopefully this post includes the picture of the engine that was supposed to go with the last post |
#83
Couldnt slide the cover over the bolt. Had to fight it off with vise grips. Then once off the engine, I still can't get it out of the cover. Doesnt matter much since the cover got broke during removal. I broke the outer edge, but noticed it is also broke inside. Dont know how that happened.
Also, that cover is a 527292 which is supposed to be from a 76-79 400, so I can only assume that when that aftermarket WP was installed, maybe the original timing cover was replaced as well |
#84
Had Quadrajet Power rebuild that carburetor. Really pleased with how it turned out. Hopefully it runs as good as it looks. Original alternator is also out for a rebuild. Gonna clean up the engine bay when everything goes back together.
| The Following User Says Thank You to F Body Freak For This Useful Post: | ||
#85
Quick question also.
Are those timing covers factory installed with no engine paint on them? I dont see any evidence on paint on mine, but according to the part number, its not the factory one. |
#86
They are painted at factory.
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
#87
Sometimes they need replacing along the way.
The last water pump replacement might have pulled out the threads with a couple of bolts. All kinds of things can happen to them. Some of them require 2 removable tube assemblies , and a divider plate. Internal parts. |
#88
Any suggestions on which engine paint to use. Is this Inline Tube 66-70 Pontiac Blue Silver metallic the correct shade?
According to them, the color changed in 71? |
#89
Yes, that would be correct for a '70.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#90
Thank you sir. It appears to have some of that color left on the harmonic balancer, behind where the pulley was. I think the intake & front of the motor has been touched up at some point with the 71 shade of engine paint
#91
Is this clutch fan correct for my 70? And what is a good way to clean these?
#92
Got around to decoding my distributor & finding the VIN number down by the timing cover.
Distributor is original. Date code M 9 14 |
#93
Is this radiator original??
It has Harrison stamped on it. Has the letters C U stamped on the tank Has a tag stamped on it that I assume came from a Radiator Shop repair, possibly. It says 003271 Nelton Radiator Phoenix, AZ 80564 5 25 |
#94
CU on one tank would be correct for an auto trans 70 radiator. There should be a code on the other tank as well - "IF", I think.
#95
Also, we’ve seen quite a few original 4 speed cars with the automatic, CU Radiator, and have the big head plugs in the cooler line openings. Seen this on multiple years. |
| The Following User Says Thank You to Tellyshavilli For This Useful Post: | ||
#96
Thanks guys!
I'll have to look on the other tank for a stamping. I didnt look at that one. I think its neat also that a radiator shop put that tag on it at some point. I have quite a few maintenance records from the original owner. I'll have to look through those again & see if I see one from that shop |
#97
Took a look on the other tank & found an I F
#98
Ended up needing a recore on my original 70 Radiator.
Ellet Radiator in Akron, OH did the services. Looks like they did a nice job. Ready for another 56yrs of service. 👍 |
#99
In case anybody missed it, in the What did you do to your Pontiac today thread...
After 4 long months, I finally have my 400 back together. Quite pleased with the results. 56yrs & 99K miles sure left a lot of dirt & grime in there.😳 Hopefully no issues when we put some "fire in the hole". 🤞🤞🙏 |
| The Following 3 Users Say Thank You to F Body Freak For This Useful Post: | ||
