Old 02-23-2026, 01:45 AM
F Body Freak F Body Freak is online now
Got this 400 tore down a little...
She put up a good fight, but I eventually won. Ended up cutting one of the long bolts that ran thru the WP & timing cover into the block that wouldn't break loose. Everything didnt slide off like I read tho.
  #82
Old 02-23-2026, 01:49 AM
Lol. Still struggling with these damn pictures. 🤬
Last post has a picture of my Q-Jet I just received back. Hopefully this post includes the picture of the engine that was supposed to go with the last post
  #83
Old 02-23-2026, 01:59 AM
Couldnt slide the cover over the bolt. Had to fight it off with vise grips. Then once off the engine, I still can't get it out of the cover. Doesnt matter much since the cover got broke during removal. I broke the outer edge, but noticed it is also broke inside. Dont know how that happened.
Also, that cover is a 527292 which is supposed to be from a 76-79 400, so I can only assume that when that aftermarket WP was installed, maybe the original timing cover was replaced as well
  #84
Old 02-23-2026, 02:11 AM
Had Quadrajet Power rebuild that carburetor. Really pleased with how it turned out. Hopefully it runs as good as it looks. Original alternator is also out for a rebuild. Gonna clean up the engine bay when everything goes back together.
The Following User Says Thank You to F Body Freak For This Useful Post:
  #85
Old 02-23-2026, 12:04 PM
Quick question also.
Are those timing covers factory installed with no engine paint on them? I dont see any evidence on paint on mine, but according to the part number, its not the factory one.
  #86
Old 02-23-2026, 02:01 PM
They are painted at factory.
  #87
Old 02-23-2026, 04:21 PM
Sometimes they need replacing along the way.
The last water pump replacement might have pulled out the threads with a couple of bolts.
All kinds of things can happen to them.
Some of them require 2 removable tube assemblies , and a divider plate.
Internal parts.
  #88
Old 02-24-2026, 05:13 PM
Any suggestions on which engine paint to use. Is this Inline Tube 66-70 Pontiac Blue Silver metallic the correct shade?
According to them, the color changed in 71?
  #89
Old 02-24-2026, 09:11 PM
Yes, that would be correct for a '70.
  #90
Old 02-24-2026, 09:33 PM
Thank you sir. It appears to have some of that color left on the harmonic balancer, behind where the pulley was. I think the intake & front of the motor has been touched up at some point with the 71 shade of engine paint
  #91
Old 03-01-2026, 01:31 AM
Is this clutch fan correct for my 70? And what is a good way to clean these?
  #92
Old 03-07-2026, 12:44 AM
Got around to decoding my distributor & finding the VIN number down by the timing cover.
Distributor is original. Date code M 9 14
ID:	665931   Click image for larger version
  #93
Old 03-07-2026, 12:56 AM
Is this radiator original??
It has Harrison stamped on it.
Has the letters C U stamped on the tank
Has a tag stamped on it that I assume came from a Radiator Shop repair, possibly.
It says
003271
Nelton Radiator
Phoenix, AZ 80564
5 25
ID:	665933   Click image for larger version
ID:	665934   Click image for larger version
ID:	665935   Click image for larger version
ID:	665936   Click image for larger version
  #94
Old 03-07-2026, 09:31 PM
It says
003271
Nelton Radiator
Phoenix, AZ 80564
5 25
CU on one tank would be correct for an auto trans 70 radiator. There should be a code on the other tank as well - "IF", I think.
  #95
Old 03-08-2026, 12:27 AM
Yes, IF would be correct for the driver side tank, but we’ve also seen quite a few that don’t have any letters on driver side tank?
Also, we’ve seen quite a few original 4 speed cars with the automatic, CU Radiator, and have the big head plugs in the cooler line openings. Seen this on multiple years.
The Following User Says Thank You to Tellyshavilli For This Useful Post:
  #96
Old 03-08-2026, 10:31 AM
Thanks guys!
I'll have to look on the other tank for a stamping. I didnt look at that one. I think its neat also that a radiator shop put that tag on it at some point. I have quite a few maintenance records from the original owner. I'll have to look through those again & see if I see one from that shop
  #97
Old 03-10-2026, 08:17 PM
Took a look on the other tank & found an I F
  #98
Old 04-08-2026, 10:14 PM
Ended up needing a recore on my original 70 Radiator.
Ellet Radiator in Akron, OH did the services. Looks like they did a nice job. Ready for another 56yrs of service. 👍
ID:	667926   Click image for larger version
ID:	667927   Click image for larger version
The Following 3 Users Say Thank You to F Body Freak For This Useful Post:
  #99
Old 06-24-2026, 11:25 PM
In case anybody missed it, in the What did you do to your Pontiac today thread...
After 4 long months, I finally have my 400 back together. Quite pleased with the results. 56yrs & 99K miles sure left a lot of dirt & grime in there.😳
Hopefully no issues when we put some "fire in the hole". 🤞🤞🙏
ID:	672410   Click image for larger version
ID:	672411   Click image for larger version
ID:	672412   Click image for larger version
ID:	672413   Click image for larger version
