That is the centering snout off of the torque converter.
| The Following User Says Thank You to poncho447 For This Useful Post: | ||
I would have to say you are correct as you can see in the center where that hole is in the washer ...... guess I will have to go back and look at the T-converter snout again....... not that it matters the car it's going in is a stick anyway I was just curious and this explains it.
Thank You
NEVER DRINK DOWN STREAM FROM THE HERD
| The Following User Says Thank You to HO LEMANS For This Useful Post: | ||
Years ago a friend got bit when his 403 Olds was not drilled for stick. |
the steps in the back of the crank are there but while the engine is at the machine shop he is going to machine it for the bushing
Could it be leftover MFG tooling? Could it be from a mandrel or some factory fixture that was used to carry cranks around or to locate the completed engine during the MFG process? The tool and die shop just threw a random washer on the end of the MFG fixture, and it happens to stick in a crank some summer day in 1969?
you are 100% correct
