Old 06-26-2026, 03:32 PM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
Default crank washer?
what was the purpose of this washer in the back of the crankshaft on my 428 ?
it came right out with a pair of needle nosed pliers with no resistance the center hole looks as though it was cut with a torch as the back side is blued around the hole...
ID:	672483   Click image for larger version
NEVER DRINK DOWN STREAM FROM THE HERD
Old 06-26-2026, 03:41 PM
My only guess would be that it was needed to properly space and center a aftermarket torque converter, because I have had three 428 motors and I don’t recall ever seeing that .
Old 06-26-2026, 03:49 PM
HO LEMANS's Avatar
Steve this engine and transmission were pulled from their original home the Bonneville they came out of had never been taken apart for anything but a timing chain a new water pump and a new fuel pump
Old 06-26-2026, 04:08 PM
Dragncar Dragncar is online now
Maybe during that build time the union was fighting with management. The Freemont plant was famous for dropping a ball bearings in the bottom of a door to create a rattle so it will come back.
Whatever it is, looks like a bonehead move to me. What is the wear in the middle of the washer from ?
Old 06-26-2026, 04:18 PM
HO LEMANS's Avatar
Dragn I don't know the torque converter nose has no damage or weird wear on it so I am confused as to why it was there at all ...... this engine is original right down to the plastic from the original timing gear teeth still in the pickup screen
The Following 3 Users Say Thank You to HO LEMANS For This Useful Post:
Old 06-26-2026, 05:18 PM
Do you have two converters on hand?
If so can you compare the overall lengths of there snouts to each other?
Maybe the factory got a bad batch of converters and had to make up those washers / spacers to use those converters.
I can think of others things transmission wise that may have made for a need for a spacer also, but I will wait to post that .
Old 06-26-2026, 06:37 PM
sdbob sdbob is offline
I witnessed a brand new high volume oil pump in about 1970 with a' big' paper clip inside?! From GM! We never know.
Old 06-27-2026, 12:11 AM
Doesn't the flywheel locate the converter?
Old 06-27-2026, 03:22 AM
No.
Old 06-27-2026, 06:44 AM
The converter centers on the input shaft splines of the transmission.
Old 06-27-2026, 06:49 AM
poncho447's Avatar
poncho447 poncho447 is offline
That is the centering snout off of the torque converter.
The Following User Says Thank You to poncho447 For This Useful Post:
Old 06-27-2026, 11:29 AM
Odd crankshaft flange. In my opinion the pump bushing centers the converter. The converter snout “walks” in-out as the flex plate “flexes”.
Old 06-27-2026, 03:05 PM
Was there any washers/spacers between the flexplate and converter?
Old 06-27-2026, 04:23 PM
2nd look as someone said crankshaft centering ring off a converter. I pulled a m 40 yrs ago and cracked that ,'washer' on the converter didnt have trans just ,level,right on jack.
Old 06-27-2026, 05:07 PM
johnta1 johnta1 is online now
To me, I figure someone had a pilot bearing in there then they put automatic in. The bearing kept converter from seating correctly. After many thousands of miles all wallowed out from flexing.
Old 06-29-2026, 08:31 AM
HO LEMANS's Avatar
Scarebird ... nope no spacers just that goofy washer
Old 06-29-2026, 08:34 AM
HO LEMANS's Avatar
john the car has never been apart until now ... it's a 4 door 69 Bonneville and the only hole in the floor is from rust not a stick shift
Old 06-29-2026, 08:42 AM
HO LEMANS's Avatar
I would have to say you are correct as you can see in the center where that hole is in the washer ...... guess I will have to go back and look at the T-converter snout again....... not that it matters the car it's going in is a stick anyway I was just curious and this explains it.
Thank You
ID:	672632   Click image for larger version
The Following User Says Thank You to HO LEMANS For This Useful Post:
Old 06-29-2026, 09:05 AM
Originally Posted by HO LEMANS View Post
... not that it matters the car it's going in is a stick anyway...
The crank is drilled for a manual?
Years ago a friend got bit when his 403 Olds was not drilled for stick.
Old 06-29-2026, 09:16 AM
HO LEMANS's Avatar
the steps in the back of the crank are there but while the engine is at the machine shop he is going to machine it for the bushing
