Old 07-01-2026, 10:46 PM
lintmann lintmann is offline
Default 70 GTO Plastic Hood Scoop Repair
I was wondering if anyone could pass on some quality suggestions for a material to use to repair this scoop of mine.
I was thinking of some type of epoxy or maybe a fiberglass repair would work on this plastic scoop. Not sure what is best but I'd rather not have to do it again down the road....
Thanks!
Name:	Hood Scoop Crack.jpg
Old 07-02-2026, 11:18 AM
433lemans's Avatar
433lemans 433lemans is online now
JB Weld is a pretty good product.
The Following User Says Thank You to 433lemans For This Useful Post:
Old 07-02-2026, 10:20 PM
Yes it is, I've used it for lots of things but never for a foundation for body repair. I thought about it but not sure if the repair would show through after a while...
Old 07-02-2026, 11:03 PM
433lemans's Avatar
I'd use it. JMO
Old 07-03-2026, 09:04 AM
RFCOLEMAN RFCOLEMAN is offline
I used a J B Weld for plastic. It was light tan in color. Worked great and sanded like body filler. Held up and no issues for a few years. Sold the car.
Old 07-07-2026, 03:04 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default scoop
The scoop is molded pressed fiberglass.
I would use fiberglass to repair as it will last longer if done right.
Especially for a clean break like that.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
The Following User Says Thank You to skunkwerks For This Useful Post:
Old 07-08-2026, 09:02 PM
Well, I already bought some of the JB weld for "plastic" and started... I beveled each side and applied it to the backside. Pretty sure it will be fine but I'll bevel back the front side in a bit and use fiberglass repair there. Kind of an unorthodox repair method but I'd feel better if the material under the paint is all the same.
Old 07-12-2026, 10:58 PM
Formulabruce's Avatar
JB weld for plastics is a resin/glass product. Its not original Jb weld, and will work fine.
" Long may we DRIVE !"
