Old 07-19-2026, 07:10 PM
Terry M. Hunt Terry M. Hunt is offline
Default Which intake gasket
I may have posted this question before but can’t find it using search function. I’ll be sure to record the answer this time. Rebuilding engine in my 66 GTO using Fel Pro gasket set 2601025. It contains two different intake gaskets(see photos attached) . Which is correct A or B? A is stamped 90205 and R3. B is stamped 9980 and R 4. Also, does the printed side of gasket face the head or the intake or does it even matter?
ID:	673671   Click image for larger version
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 07-20-2026, 05:57 AM
If it has the 66 heads use B.
Old 07-20-2026, 08:43 AM
Kenth's Avatar
Kenth Kenth is offline
A is for 1972 and later intakes with any year heads.
B is for 1971 and earlier intakes and heads.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-20-2026, 04:22 PM
Okay B it is. Does it matter which side of gasket faces the intake?
Terry Hunt
Old 07-21-2026, 04:15 AM
Kenth's Avatar
They will fit only one way.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 07-21-2026, 12:44 PM
unruhjonny's Avatar
when in doubt;
Use a gasket that matches your heads.
1970 Formula 400
Old 07-21-2026, 04:13 PM
Kenth's Avatar
Again, 1972 and later intake gaskets will fit any heads IF a 1972 and later intake is used.
A 1971 or earlier intake WILL leak exhaust on passenger side on 1972 or later heads unless special measures are taken to cover/eliminate the blind hole above the crossover channel on the passenger side.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
