Old 04-16-2024, 10:06 AM
chuckies76ta's Avatar
Bumper to bumper here in Canada.
Old 04-16-2024, 10:22 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is online now
On the 8t , I ordered 10 Hastings LF222 ( made by Baldwin ) from rockauto for $4.61 . They shipped 10 Baldwin B39s . Shipping was $11 but they go for 12-15 on line .
When I wore a younger man's clothes
Old 04-16-2024, 10:23 AM
And I meant $4.61 per filter !
Old 04-16-2024, 03:46 PM
Schurkey Schurkey is offline
Originally Posted by chuckies76ta View Post
Wix filters on sale here. 51258. $6.45 each. That's like around $4.68 U.S. I bough a case. I think regular is around $11 a filter.
Photo shows "Made in USA". Good score. Is there an anti-drainback valve, and if so, what color is it--black or orange? (or something else.)
Big discussion on another forum about leaking/defective anti-drainback valves which may not be silicone rubber.
Old 04-16-2024, 04:59 PM
bhill86's Avatar
bhill86 bhill86 is offline
I second PunchT37. I use wix 51522 with my headers.
1977 Trans Am 400/4speed (swap)
Brian
Old 04-17-2024, 07:51 AM
Has the orange anti valve. Here's one I cut open a while back.
https://forums.maxperformanceinc.com...wix+oil+filter
Old 04-17-2024, 06:21 PM
Rachelsdad's Avatar
Perhaps tangentially related, I use K&N in my 2006 STS-V. For the Northstar engines - even the 4.4L supercharged one, as I have in the STS-V - the filters are all little dinky things (not like my PF7 on my '63 Bonneville...LOL).
I've had mixed results in other cars over the years with Wix, Fram, STP, and even AC. I've been pleased with the relative consistency of quality in the K&N pieces.
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
Old 04-20-2024, 08:16 AM
HWYSTR455's Avatar
I still have about 16 of the original PF24s, not sure what I'll do when those are gone, but see some are still available.
Obvious question is, are they as good as they used to be? I think someone a few years ago made comments on country of origin is a good indicator?
I ran the K&N ones for a while, they filter good, almost too good, oil psi would start dropping around 1500 miles requiring a change. At what they cost, it's questionable, and I won't run them anymore.
My experience with Purolator is they were about the same as Fram. Granted, it's been a long time since I've used them, but still no reason to go back in my book.
I've run Wix before, was ok with them, was during a time of lack of PF24s. But that too was a while ago. No problems that I can recall.
Like it or not, production of items can move offshore, depending on current 'administration' 'occupying', probably going to have to deal with that at some point.
IMO, just watch the oil psi closely, regardless of what you're used to using, and adjust accordingly.
Old 04-22-2024, 01:45 PM
General Z General Z is offline
K&N 2006 for me. I actually read higher pressure with it than I do with a Delco filter.
Old 04-22-2024, 02:48 PM
I'm curious, Where are you taking your oil pressure reading from? Thx
Old 04-22-2024, 02:53 PM
If I remember correctly, on top by the distributor hole. Going off of memory here.
Old 04-22-2024, 02:59 PM
maxpowerta maxpowerta is offline
Is that a wholesale price? I just checked here in Calgary and the want $11.50 each.
Old 04-22-2024, 03:04 PM
I looked up the spec for micro rating and didn't find any. Does says it's a high flow filter. Maybe that's why higher pressure reading. More flow. I always assumed that filter was more restrictive. Thanks
The Following User Says Thank You to chuckies76ta For This Useful Post:
Thread Tools
Display Modes
