I know with 455s, or long stroke engines, there's a chance of sucking the stock pan dry, and the general fix is to run an qt extra. Windage is the factor, as well as slosh & slow drainback.
There are threads here about it, search it. If you have a windage tray, it helps with windage, which is the only drawback when running 'too much oil'. Of course, you don't want to fill the engine up to the valve cover breathers, but that's a no-brainer. Most racers etc will tell you windage can cost HP, general consensus is in the 5-10 HP range. If that's felt as a dramatic difference, you're probably only making 100hp total. I run 7+1 in my Canton pans, the docs are not right in saying 6+1, the pan is listed as a 7qt, not a 6qt. So you be the judge. .
Pretty sure the calibration of dip sticks is base off the pan rail on the block.
I’m going to use a Milodon 7qt. pan on my motor. Because I added splayed caps to it, it’s easier to have a pan mounted dipstick. To determine the correct fill level, I took a factory pan and added 5 qts of water to it. It measured 4” from the pan rail. I then took the Milodon pan and added 7 qts of water to it. That also measured 4” from the pan rail. That will put my Spotts windage tray about an inch above the oil with the engine not running. I will set my dipstick full level at the 4” mark and add whatever amount is needed to read full. I am running a remote filter and possibly an accusump so the total amount hasn’t really been determined yet.
" Darksiders Rule "
Accusump doesn't matter, as long as it's filled prior to calculating oil volume/level. (Dipstick calibration) .
Just a follow up on this. I changed the oil today. I used a standard Wix 51258 filter and put in a total of 6 qts. Ran it for about 10 minutes checking for leaks then let it sit for another 10 minutes or so. Interestingly, that filled it right to the full line on the dipstick. So even with essentially 100% aftermarket parts all mixed together, it turned out correct.
On a side note, I also collected a sample to send for analysis.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
Some of the after market stock replacement pans hold more than 6 QTS due to their shape.
Tim Corcoran |
On my IA i just had to grind a little on the splayed cap to use a factory dipstick hole . Bolted tube to windage tray. Drilled a hole n Canton pan baffle for dipstick.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
I have the BOP windage tray. I wish I had gotten the Spotts tray. I should have asked about that here, oh well. I didn't realize until long after the engine was done that the BOP tray requires "heavy" modification for a IAII, according to the Butler site. I have no idea what my builder had to do to fit it but he never mentioned anything about it to me. Anyway, so that's how my tube is routed.
Not sure what stroke has to do with oiling. Now a long stroke engine will pull a very hard carb signal. |
Thread Tools | |
Display Modes | |
