Old 08-27-2003, 09:48 AM
all_ryze all_ryze is offline
I'm planning on swapping my POS muncie with the Richmond 5 speed!
Anyone using the 5 speed, if so, whats your opinion.
I plan on flogging it at the strip with a 150 shot of spray for next year!
MOTOR CITIES FINEST
PHS Documented "REAL JUDGE"
12.53 @ 110.68 on street tires, through the mufflers and a 4 speed!!
Worlds Fastest Documented GTO JUDGE!
MOTOR CITIES FINEST
Old 08-27-2003, 10:21 AM
FirebirdDave FirebirdDave is offline
Thats supposed to be a great trans, basically the old Doug Nash Trans. Are you buying the on with an overdrive or not?
69Firebird roundport/roller455
70Catalina 455
72Skylark Buick 455
89 Iroc 305 stock 192RWHP/263RWTQ
I cant leave anything alone.
336rwhp/425rwpft
12.62 @ 108.60
70Catalina 455
72Skylark Buick 455
Old 08-27-2003, 10:24 AM
Steve Barcak's Avatar
I've run a Nash (Richmond) 5spd on a few street/strip GTOs over the years and I've known a few others who have too. It's a nice trans but, gear the car accordingly. I have a customer who put one one his mildly stock '78 T/A and left in the 3.42 gear. The car went slower with the 5spd and he never used 5th gear at the track. Depending on your combo gear it taller than mornal because of the 3.25 1st gear. A 2.56 through 3.08 may be best. The 6 speed for about another grand can be a waste of money. I know of a guy who runs one in his GTO without benefit. The Pontiac has a flat torque curve and does not need that many gear changes. Now, if you are running "Z" rated tires and want to run at long periods at over 140, then the 6 speed is for you.
Steve www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 08-27-2003, 03:30 PM
Skip Fix Skip Fix is online now
One thing to look at too is the lower the first gear usually the lower the torque it can handle. I know they told me that with their drag/roadrace version(straight cut gears no synchros or speedo)They have custom gears available, especially if you order one new.Could get what ever you want.
Old 09-01-2003, 01:15 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
I have run a Nash 4+1 for a couple of years at the track now after breaking numerous Super T10s
Box is great but from what I understand Richmond dont sell a straight cut non syncro version anymore (Shame on them) so the helical unit is the choice
As others mentioned whatch the ratios. With a 455 and a 3.25 first in the boxes it gets real easy to wreck some driveline parts (if you ever get it to hook up)
A 3.25 first and a 4.11 gear dont work!!!!!!
(30 ET street) no fault of the tyre
A 3.73 worked better and hopefully soon we will see what a 3.20 will do with a small shot
Look the the ratio of 4th with the boxes to determine your "real" drive ratio in top at the track. Mine is still 1.16 (5th is 1:1) which calcs out to around a 3.7 with the 3.20 which should be good
Starting line ratio will be 10.4:1 which will be alot more usable than the 13.35 or 12.1 we have used in the past. More gear slowed the car down so were going in the other direction
Working on going faster!!!
Working on going faster (and now staying dry at the same time !!)
Old 09-01-2003, 06:40 AM
I think you are right they were phasing out the straight cut boxes a few years ago when I bought some gears for one. They weren't available complete anymore. Now a its a 2.88,2.22,1.77,1.33,1.00 box.I think Jerico and Liberty boxes took away their market.
It shares alot of similarities with the street box. With some BIG snap ring pliers you can swap any part in it.
Old 09-01-2003, 08:02 AM
tom s tom s is offline
for serious drag racing with a stick shift I think the Jerico cluthless is the answer.Anyone that was at Norwalk and saw Ric and Dave Johnson run 9.0s on the throttle in their Pro Nostalgia cars can attest to the strength and smoth shifting on the gear box.
Old 09-01-2003, 12:46 PM
Bartman Bartman is offline
G-force who makes Prostock clutchless trannies can also put you something together for just a little more than a Jerico and a lot less than a Liberty.
Bartman
Ponies run but Birds fly
Old 09-01-2003, 01:15 PM
455-4+1's Avatar
I agree on the later model aftermarket boxes for "serious" racing but for a whole lot less coin I feel the richmond would be just fine in this application. Spend the extra money saved by buying the richmond on a good clutch, scattersheild and driveshaft. (Hows your diff ???)
I probably would be running a Jerico here to if they were not $7000 NZD compared with a couple for a Good used Richmond. (Used Jericos seem to go for the ame price as new here LOL)
Get the right clutch and you will be shifting (not banging) gears for along time
Is a clutchless trans legal in Pro Nostelga ?????
Old 09-01-2003, 01:36 PM
Yes it is,cant use a Lenco though
Old 09-01-2003, 05:07 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
http://www.ddperformance.com/GM%20T56.htm
T56 Kit
http://www.fortesparts.com/tremec/index.html
Tremec 5spd kits
http://www.sallee-chevrolet.com/Richmond/
Richmond 5spd
I personally am going with the Viper/Muncie Replacement T56.
Old 09-02-2003, 02:42 AM
455-4+1's Avatar
So if you run a clutchless trans
What on earth do you do with your left leg for the rest of the pass after leaving ????
kinda like an auto really LOL
Wheres the nostalgia in not stabbing the clutch whilst pushing the loud pedal through the floor???
Old 09-02-2003, 12:59 PM
White Warrior White Warrior is offline
You rest your leg for the next run. The clutchless has one drawback,it can't be used on the street-you can't downshift it and it won't stay in anygear except 4th without a load on it.It's hard to drive even in the pits,but if you want a tenth off your et,it's the hot ticket.
Old 09-02-2003, 01:41 PM
thanks Dave,was hoping you would jump in.Do you know anyone that has used the road race Jerico?Tom
Old 09-03-2003, 10:28 AM
Dave just going through a pile of old pictures and some old NMCA Nostalgia SS with the White Warrior wheels up! I think at Memphis.
Old 09-03-2003, 08:11 PM
tim dean tim dean is offline
On of our racers in Pontiac Drag Days here in So Cal broke the Jerico he had behind his 455. He's using an automatic now. Pontiac torque.
