Old 09-19-2004, 08:40 PM
Rusty 68 Rusty 68 is offline
Does anyone know how to test power window motors once they have been removed from the car. I assume a direct 12v connection could fry them. Thanks
Old 09-19-2004, 08:45 PM
cal1808 cal1808 is offline
12 volts to one wire ground to the other tests one way, switch the wires tests the other.
Old 09-19-2004, 09:17 PM
Forrest's Avatar
Forrest Forrest is offline
ground the motor, then apply 12 volts to one of the terminals,(motor should go one; clockwise or counterclockwise)then apply 12 volts to the other terminal ( motor should go the opposite way)only apply the 12 volts to one terminal at a time! of course there is no load on them, so it is hard to tell if they really work well
