Old 01-14-2005, 02:41 PM
GTO71's Avatar
GTO71 GTO71 is offline
Some pictures of my engine that will be runing soon, It is the orignal 71 400 Block 0.60 over with the original M-21 four speed that I redid a few years ago. Tell what you think this Goat will run with a 3.55 gear. It will look stock when it is done to the novice.... Quadrajet, factory air cleaner, intake painted blue, ram air manifolds. It is a numbers matching car, except I am putting a of 6X-8 on it but I have the original 96 heads in my garage.
GTO71's Avatar
Old 01-14-2005, 02:44 PM
GTO71's Avatar
Eagle rods in a stock lenght with a Aries custon made piston, Those slugs are very light. Full floating wristpins.
Old 01-14-2005, 02:47 PM
GTO71's Avatar
Close up of the Piston, I am using a Total Seal Rings.
Old 01-14-2005, 02:52 PM
GTO71's Avatar
A shot of the Crank original Nodiular Iron Crank .020 under rods. .010 under mains. Indexed and dementionalized. I suck at spelling!!!!!!! Had to remove a lot of weight cause of the lighter pistons.
Old 01-14-2005, 02:56 PM
GTO71's Avatar
A pic of the combustion chambers, chambers are exact same cc's at 102 chambers angles have been"smoothed out"
Old 01-14-2005, 03:00 PM
GTO71's Avatar
Exhaust Ports tha have been ported and polished, 2.110 &1.660 stainless steel valves pretty light valves ones too.
Old 01-14-2005, 03:03 PM
GTO71's Avatar
Intake Ports Smae work done.
Old 01-14-2005, 03:06 PM
GTO71's Avatar
No expination needed!
Old 01-14-2005, 03:10 PM
GTO71's Avatar
Comp Cames XR288-10 Hyd Roller Cam
Old 01-14-2005, 03:15 PM
GTO71's Avatar
1971 WT Numbers matching block, I deburred it and removed any flashings on the block.
Old 01-14-2005, 03:20 PM
GTO71's Avatar
I reccomend polishing the lifter gallery area, I spent a frw hours on mine but it is verry messy, I have seen them look like a mirror before
Old 01-14-2005, 03:26 PM
GTO71's Avatar
Crosshatch Pic
Old 01-14-2005, 03:37 PM
GTO71's Avatar
1971 Original M-21 That I rebulit thats gonna go with my engine, I will be using the stock flywheel and a centerforce dual fiction clutch assembly.
Old 01-14-2005, 03:40 PM
GTO71's Avatar
Another Shot!
Old 01-14-2005, 03:55 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by GTO71: I will be using the stock flywheel and a centerforce dual fiction clutch assembly. <HR></BLOCKQUOTE>
Looks nice! Since you are doing all that why not pop for a new steel flywheel?
Old 01-16-2005, 09:08 AM
tremo's Avatar
tremo tremo is offline
Very nice. Love 'dem clean parts! Keep this thread updated on your progress...
Good luck!
Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
Old 01-16-2005, 01:47 PM
screamingchief's Avatar
Yeah,looks great,should run real strong too! I would think it'd be a blast to drive,just don't get too crazy without a scattershield!
This space for rent...
Old 01-17-2005, 11:41 AM
Formula jg Formula jg is offline
That sh$t looks so good makes you want to just sleep with it.
Old 02-10-2005, 04:12 PM
GTO71's Avatar
The Crank and Cam in the block. Nodluar Iron Indexed Crank.
