Old 03-23-2005, 08:21 AM
Larry Navarro's Avatar
keep in mind that the tomahawk, the HSD and the T2(all with a 1" spacer) will fit a t/a with shaker.....just in case "fine" tuning or NOS comes into play.
ask me how I know.
  #62
Old 03-23-2005, 10:27 AM
Big Injun's Avatar
Big Injun Big Injun is offline
I spent about 8 hours of work porting the HSD to get the numbers we did...and it did not have the torque curve of the Tomahawk. So if time and money is no object, go to it...run a HSD if you can find one.
Take nothing away from the Performer RPM, but to really make it work you need a 1" spacer. That is what I had to do with the GeeTO TIGER to maximize its performance. I could only do this because of the VFN fiberglass hood.
The Tiger is now on display at the Petersen Automotive Museum. When it comes out it is going to get freshend up and we will be running a Tomahawk on the Tiger.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
  #63
Old 03-23-2005, 10:37 AM
10second70GP's Avatar
10second70GP 10second70GP is offline
big injun are you going to try this on the tiger .
  #64
Old 03-23-2005, 11:21 AM
slowbird's Avatar
slowbird slowbird is offline
So the HSD in this test was not stock but had 8 hrs of porting done to it, correct? All the other intakes were stock then?
  #65
Old 03-23-2005, 11:26 AM
alright that answers my question. looks like i'm going to get one when and see if i pick up over my torker 2
  #66
Old 03-23-2005, 11:57 AM
lemans411's Avatar
lemans411 lemans411 is offline
do you feel this intake will flow good enough for a 700 to 800 hp blow through application ?? i need the shorter intake for hood clearance for my carb box or bonnet . i have a wenzler 4 bbl intake now and it is pretty tall how much shorter than a rpm is it 5/8 " shorter?
thanks,
rob
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #67
Old 03-23-2005, 01:07 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
The Tomahawk is 1 1/4 shorter than the RPM. And yes with a bigger cam and high flowing heads I have no doubt the Tomahawk will realy start to shine!! Or shall we say it will take the RPM's scalp!! I think it will do well on the Tiger!!!
Be Cool,
Am I glad I got out of the business I was in? HELL YEAH!!!
  #68
Old 03-23-2005, 01:53 PM
pontiacjeff pontiacjeff is offline
I have a HSD that had all the webbing milled off, carb plenum opened up, gasket matched to stock gaskets, crossover divided, and polished. it looked just like the Tomahawk pictured on that dyno chart. I paid 125.00 for it used and spent over 20hrs on it.
I wish the Tomahawk was available 9 mos ago...
Jeff Ianitello
  #69
Old 03-23-2005, 03:55 PM
KARGUY KARGUY is offline
Was the 1 inch spacer used in the testing an open or 4 hole?
KG
  #70
Old 03-23-2005, 04:02 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
i see this manifold appears to have bosses for multi point injection, yes? or, are those for nox nozzles?
if its for fuel injection, are there any plans to run a test for that?
costs too much
  #71
Old 03-23-2005, 04:19 PM
Big Injun's Avatar
Open spacer...
Bosses for NOS or FI...
...and yes, great for a blow through application.
Slowbird...the HSD was ported.
We have confirmation from the factory that 40 Tomahawks will ship on March 30th.
Order yours now!
[email protected]
www.4mypontiac.com
  #72
Old 03-23-2005, 08:03 PM
issach428's Avatar
issach428 issach428 is offline
so now that it has been tested who was it you said was going to track test it now?
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
  #73
Old 03-23-2005, 11:12 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Here is what I got from this.
If the Tomahawk is 1 1/4" smaller then the RPM than running the 1" spacer brings the intake volume back into the fair comparison category.
If you add a 1" to the RPM, you would really need to add a 2" to the Tomahawk to be apples to apples in volume.
The 1" spacer numbers are really nice and if it comes polished with the FI bungs for $300, its a great deal.
Have you considered putting together an EFI package with the Tomahawk down the road?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
  #74
Old 03-24-2005, 03:48 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
i have no problems with my rpm and 1' spacer under my hood and my hood is flat. (71 grand prix) i dont run an air cleaner but im sure it wouldnt fit. but i did have an aircleaner on before the spacer and the car was slower. 12.13 with the spacer and no aircleaner compared to high 12.25s without the spacer and with a aircleaner. so besides worry about the carb gettin alittle dirty why the hell would i use an air cleaner. the rpm numbers are very close to the tomahawk and is advertised as the best of both worlds for a street car. alot of street cars gonna run 300cfm heads or the almost 400cfm tigers?? i know im not im still on 250cfm 6xs. you cant beat the price tho especially since i would like to swap to a T2 which now will be a tomahawk instead. they need to be ordered in advance?? thank u
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
  #75
Old 03-24-2005, 04:55 PM
Dragncar Dragncar is offline
The carb "gettin alittle dirty" is not the point of an air cleaner.The point of a air cleaner it to keep dirt out of your expensive motor.
  #76
Old 03-24-2005, 07:14 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
I'll be buying a polished one! Can't wait to get it.
Thanks for the hard work Dave and Ken.
_________________________
Sonny Barger
  #77
Old 03-24-2005, 07:21 PM
Lets all not forget Dave Bisshop at SD Performance! He spent 25 hrs making the Tomahawk flow what it flows! If it was not for Dave Bishop this would NOT have happened.
Be Cool,
  #78
Old 03-24-2005, 07:24 PM
6567GTO's Avatar
OOPS! Thanks to Dave Bisschop as well!
Sonny Barger
  #79
Old 03-24-2005, 07:43 PM
Big Injun's Avatar
Since we are all being so expressive...we need to thank Phil who was first to come up with the name...
[email protected]
www.4mypontiac.com
  #80
Old 03-24-2005, 08:15 PM
Yes, a big thanks to Dave Bisschop.
I'm sure Dave appreciates the recognition, especially with his name spelled correctly.
