If you have Ram Air 3 manifolds, you know what a pain it is to tighten the one bolt at port 7.
What tool(s) have you found to work the best when working on these manifolds? Personally, I found a cut down 14mm socket works somewhat ok, but if anyone has found a better tool, like a snap-on offset wrench, whatever...let's hear it. |
Socket with the motor jacked up on that side only. Watch your fingers.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
