Old 09-27-2004, 10:51 PM
URHONOR's Avatar
URHONOR URHONOR is offline
OK My Judge is WT1 stamped! Is it one of 442, or one of 242, not that it really matters, I love the car! Being stamped on the data plate as WT1, and a number 1 in the vin means that it is canadian built, not canadian destined correct. I have a three page documention on the car from GMoC, plus assembly line vins with options 10 cars prior and 10 cars after
mine. CDN2PL2 if I supplied you with my info would it help your research.
Old 09-28-2004, 06:31 AM
peppergreen's Avatar
peppergreen peppergreen is offline
CDN2PLS2,
I have a build sheet from an Oshawa 70 Judge that I was looking at this spring. I can fax it to you if you want for records, stats, comparisons, etc.....I can scan or fax.
Brent
"Drive a GTO".......Iggy Pop-Lust for Life
Old 09-28-2004, 02:53 PM
CDN2PLS2 CDN2PLS2 is offline
That would be GREAT guys,I'm always looking for more to add to the records.
Old 09-28-2004, 02:56 PM
Oh,by the way none of the 17 Judge convertibles for '71 were sold new in Canada FYI.
Old 09-29-2004, 06:26 AM
CDN2PLS2,
Let me know your fax number and I will send it to you first thing tomorrow am.
[email protected]
Brent
Old 09-29-2004, 07:49 AM
Larry P's Avatar
Larry P Larry P is offline
CDN2PLS2,
I have a 70 Judge also that I beleive is an Oshawa car I have the PHS copy I can fax to you and I can email you a photo of the cowl tag if you would like.Its stamped WT1,M20 etc.I cant remember all the codes on it.
Larry
[email protected]
Old 09-29-2004, 07:59 AM
Judge273's Avatar
Judge273 Judge273 is offline
On the subject of production numbers. Is there a source for 70 Judge RA IV numbers. I would like to know how many were equipped with auto trans. I know 140 for all GTO's of that how many were Judge's.
Mike/Illinois
Old 09-29-2004, 01:07 PM
This is what I have.
Pontiac=41
Fremont=9
Arlington=12
Baltimore=10
TOTAL=72
RA IV M40 coupes.
Old 10-04-2004, 09:51 PM
I just went to that link gtoalley.Did nobody else notice the backwards stripes on the first two cars??
Old 11-09-2004, 03:10 PM
trishieldchief's Avatar
288 Judges were built in Oshawa Ontario in 1970
Fred Simmons documented this years ago.
All GTO's including Judges had option codes stamped into Firewall tag.The Fisher body plant did this for modifications beyond the norm for any options needing special body modifications ie D55 console (Fisher had to weld brackets on to floor ,M21 (they had to cut floor shift hole in floor,WT1 hole in firewall for RAMAIR cable.
I live in Ontario and currently own an Oshawa
built 70 GTO Judge that has D80 for spoiler, M21 for close ratio Muncie 4 speed because my car is a 3:90 rear axle car D55 for console and WT1 for Judge option
Regards,
Rich Johns
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 11-09-2004, 11:37 PM
Yes Rich,that was stated in the second post.I see you've finally found this site.Mark
Old 11-12-2004, 06:55 AM
288 Judges were built in Oshawa Ontario plant not 442!
Rich Johns
1987 GN Astro Roof
Old 02-13-2007, 01:21 PM
the70OOJudge's Avatar
the70OOJudge the70OOJudge is offline
Send a message via MSN to the70OOJudge
Hi.. Im just wondering where Fred Simmons got those numbers from? That "288" of the "442" 1970 GTO's built in Oshawa Ontario were 1970 GTO Judges. One thing for sure things sure get interesting with GTO's..
I only have a 3" x 2" rectangle piece of my build sheet left!! It was eaten by a vermin that decieded to live in my back seat and make a nest out of it too!!
1970 OO Cowl Plate
http://forums.maxperformanceinc.com/...6&d=1159298668
Pete Stack
Old 02-13-2007, 05:56 PM
Oshawa built 288 Judges in 1970 NOT 442
The 442 # is the total # of 70 Judges Sold NEW in Canada in 1970 not the actual production of the Oshawa assembly plant.GM of Canada records every car regardless of where it was built as recorded total # sold new in Canada.
The balance of 154 Judge cars are probably 50 RAIV Judge cars built from Pontiac head plant because Oshawa only built RAIII Judges and the other 100 or Judges are from other assemble plants in USA ie Freemont California is a lot closer to the western provinces of BC and Alberta than Oshawa.
I hope this clarifies the #'s for everyone.
Fred Simons is correct 288 Judges built in Oshawa.
Old 02-13-2007, 07:23 PM
Makes perfect sence to me Rich. If they have the numbers on the Judges what about the numbers on the 70 GTO's built in Oshawa? I read my buddies papers he got from GM of Canada and I thought I saw the number of 442 but it most likely ment the same that 442 was the total new in Canada.
His is a 1970 455 Automatic HO car and it has the designator #1 in the vin making it from Canada. Be nice to have all the numbers out of that Plant for GTOs for that year heh?
http://www.gtoalley.com/70judgec.html
