Old 10-17-2004, 10:31 PM
TUNNEL PORT's Avatar
TUNNEL PORT TUNNEL PORT is offline
jamaca85,
Yes I just got the add up & it was $365 + $29 not the $385 for the auto version only.
Old 10-23-2004, 10:49 AM
shotgun shotgun is offline
PY Staff -Tech
TP,Any chance of getting a pair for a 71 TA 4 speed(really tkoII)with the last part of the header collector(oval to round transition) not attached?
I am building a G Machine for a customer and we are using 3" oval tubing from Dr Gas.
I would like to go right to oval,this may make it tuck inside the subframe.I have already "raised" the floor my only concern was how low the collector flange hangs.
I think this would solve that.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
  #163
Old 10-23-2004, 09:36 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
how about whY-Tri brand headers?
is this thing on?
  #164
Old 10-23-2004, 10:02 PM
shotgun,
I'll have to check with them on Mon on that. They make there own collectors but I don't know if they can make it oval.
Ron
Old 10-24-2004, 06:17 AM
PY Staff -Tech
If they can't,just either leave it off or just tack it.I can rework it. I will wait to hear. Thanks
  #166
Old 10-24-2004, 06:59 PM
tafanatic tafanatic is offline
Ron, can you give us an update on the headers?
  #167
Old 10-25-2004, 10:51 AM
gearbanger's Avatar
gearbanger gearbanger is offline
Yes, please. An update on the 64-72 A-body
  #168
Old 11-03-2004, 07:46 PM
Formula8's Avatar
Formula8 Formula8 is offline
I can't speak for the methodology used but check out the bottom of this link for some performance testing done with the new Tri-Y's.
http://forums.performanceyears.com/g...11&m=850109068
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
  #169
Old 11-05-2004, 07:24 PM
Hopefully, the final design (auto & 4-speed) will arrive any day now. I'm anxiously awaiting the arrival of the big brown truck!
  #170
Old 11-08-2004, 03:45 PM
lumarkhood lumarkhood is offline
Me, too.
Ron had hoped for a early November ship/arrival date.
I'm waiting on a coated set for a 4-speed, so I'll probably be one of the last to get the headers. If/when I do receive them, I will post here.
Trans Am's, Formula's, Mustang, GN...
  #171
Old 11-15-2004, 05:12 PM
Latest update. The O-port headers should be done by Friday. With any luck, and Ron could sure use some, the painted sets will ship next week (Thanksgiving will most likely delay things somewhat). The coated sets will take another week or two. Once these are done the D-ports will be completed, painted or coated, and shipping in early December. Ron wants everyone to have theirs well before Christmas. He is also hoping to have the Kaufman's run a dyno test for HPP. As my son would say, "That would be way cool," and would help validate the unconfirmed testimony of a 1/2 second gain for a SD-equipped car.
  #172
Old 11-22-2004, 03:02 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
I just got off of the phone with "TP" Ron, and my set of RP 3" collector ceramic coated Tri-Y's should be here be Friday. I'll post a pic or two in the "Street" section - for more exposure - once I receive them.
Oh, one other thing, I am truly honored that Ron picked my moniker - "Tri-Y-bal Tubes" - as the official name for his new headers.
Thanks for everything, Ron!
Regards,
"455HO" Lloyd
  #173
Old 11-22-2004, 07:24 PM
Lloyd I think we need that boat here in Houston!!
  #174
Old 11-23-2004, 08:36 AM
Lloyd-TX's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Skip Fix:
Lloyd I think we need that boat here in Houston!! <HR></BLOCKQUOTE>
Ditto that, Skip!
I feel for the framing crew working on our new home, wallowing around in all that pig slop right now!
Regards,
"455HO" Lloyd
  #175
Old 11-23-2004, 10:43 AM
Skip & Lloyd,
Are you refering to the boat in my sig?
Ron
Old 11-23-2004, 01:20 PM
Yep it could drive down the streets here!
  #177
Old 11-23-2004, 05:07 PM
Skip,
That boat has a Pontiac 455 in it with 510hp. Can we be able to hit 81mph(GPS)on those streets? It only needs 1 1/2' of water.
Ron
Old 11-23-2004, 05:14 PM
Trev Trev is offline
I hope you made a special set of 'Upside Down Tri-Ys' for it! (More roof clearance)
  #179
Old 11-23-2004, 06:10 PM
Or would that be Bridge clearance
I will be getting a new set of 4-tubes for it though & later I plan to get a Butler aluminum 540 next summer. If everything works out or I win the Loto.
Ron
Old 11-23-2004, 07:53 PM
A buddy had a 455 Olds jet boat we skied behind. It hauled enough to scare me on the water! Could pop three skiers up easily. Why did they use so many Olds motors in those even compared to BBCs? They have about the same oiling system as our Pontiacs.
