Old 02-25-2004, 12:58 PM
BOWE62 BOWE62 is offline
Well now that I have the 3.55 gears in, more fun to drive, but hiway cruising sucks and fuel economy went from bad to horrible(Holley is part to blame, need to get a Qjet). I have read past posts on this upgrade, but just to be sure, from what I understand,200R4 is a direct bolt in, just need TV cable vs 700R4 you must get a bellhousing, shorten driveshaft, move crossmember back...too much hassle, so if I find a 200r4 which is built up to handle 450hp, my stock 389 should be ok...question I have is my his/her shifter, I actually use it a lot to shift manually, how will that work with 4 spd auto since there are only 3 slots for drive on the shifter...Do I need to get another shifter, I would hate to take out the stock shifter.Those of you who have upgraded to 700r4/200r4, what did you do?? thanks greg
Greg Bower
Greg Bower
Greg Bower
Greg Bower
Old 02-25-2004, 01:03 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Greg,
Contact Shiftworks for a kit to modify your shifter/ indicator so you will be able to use all the gear selections. Let us know it works.
Josh
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 02-25-2004, 01:04 PM
......they MAY have something to do this modification on the his/ hers but Im not positive.
Old 02-25-2004, 02:48 PM
thanks, it appears shiftworks has just what I need to use my original shifter...
Greg Bower
Greg Bower
Old 02-25-2004, 06:07 PM
TTS's Avatar
TTS TTS is offline
Your gonna need a driveshaft yoke. The diameter is different.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 02-25-2004, 08:34 PM
You can get a lockup controller from Jegs or Summit I think so you can control the locking/ unlocking of the torque converter. You just have to remember to unlock it when you stop.
I think I remember reading about someone did the same conversion and wired the switch to disengage lockup when they stepped on the brake pedal.
Old 02-25-2004, 08:36 PM
Also let us know how it works out...I want to do the same conversion on my '67 Tempest.Thanks!
Old 02-25-2004, 08:54 PM
slgenge's Avatar
slgenge slgenge is offline
High performance pontiac did a artical a couple of years ago on this swap send me your email and i will send it to you
Shawn
1964 Catalina 2+2, 389 Tri-Power , 4 Gear , 8 Lugs Sold 2023
1966 GTO, 467 Stroker Mid 11.58@114 Mph
2002 Firehawk Vert, SOM , 6 speed, all the SLP Goodies
1968 Firebird Race Car,525 CU IAll 10.14@133 MPH
1970 442, # Matching 455, 4 Speed W-25 hood
1972 Buick Stage 1 Flame Orange
Old 02-26-2004, 06:58 PM
Malky Malky is offline
I got a recent quote from Bowtie Overdrives for 2004R to replace TH350 (so not exactly what you are doing). It adds up: level 3 tranny (strongest) 1284, 2200 torque converter 154, install kit ie pressure gauge, temp gauge, and in-line filter (mandatory for warranty) 67, TV kit 110 (expensive but trick), 3-4 speed linkage adapter 85, speedo gear and hsg 44, inspection cover ?, dipstick ?, lockup TC wiring kit ? Total 1947. Like Cliff R is always saying, it takes moolah to make a strong 2004R.
Malcolm
Old 02-26-2004, 10:27 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Hurst makes a 4-speed Dual Gate shifter for the 200-4R and 700-R4 that can be mounted in a console if one desires. I have one in my 66 GTO with factory console. Only difference (visually, anyway) between the original Pontiac Dual Gate and this new one is the shift lever is bent like an original Oldsmobile unit.
Old 02-26-2004, 10:34 PM
wheelspin's Avatar
I installed a B&M Quicksilver shifter in my signature GTO below. It allows precise control over the forward gears in my 700R for racing, and looks great on my stock console.
Les
66 GTO Sport Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
