Old 02-21-2004, 05:40 PM
yankeeralph yankeeralph is offline
I need to change my pressed in rocker arm studs with screwed studs and I was wondering if this can be accomplished with the heads still on the motor in the car. Also, should the screwed studs be loctited in place. I should have had it done when the heads were off the car but for some reason my machinist did not bring it up. Thanks
Old 02-21-2004, 06:14 PM
Floyd Hand Floyd Hand is offline
Answer to your questions: No, No, and yes you should of.
Old 02-21-2004, 08:38 PM
Thanks Floyd, I have never done this before but that doesn't mean I won't try. After all, everything we do in life we have never done the first time we do it and look where we are today. (of course we get a lot of bumps along the way).
What are the pitfalls of replacing the studs with the heads still mounted? I was thinking that as long as I keep all the shaving off the head (practice good FME) that I should be OK. There appears to be enough room even with the springs still installed. I am a very good "Handyman" but of course not an expert mechanic.
My best bet would probably be to get a better set of heads anyway. Right now they are 1968 #15 (small valve) and am looking to install some 6X-4 (maybe). A head changout is a lot easier I know, except for that darn bolt by the AC box!! Any suggestions on best course of action to get that bolt torqued properly?
Thanks for your insight!
Old 02-21-2004, 09:10 PM
cioccoj cioccoj is offline
I did mine on the car with no problems. After i got the old ones out, i put a rag around the boss to catch any metal from tapping them and then just tapped the holes. I did loc-tite mine in.
Jody
Dont even consider trying to install screw in studs yourself unless you have a machine shop. If you try hand tapping the holes the studs will not be straight and you will end up with strange vavle train wear.
Old 02-21-2004, 11:37 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
H-O Racing used to sell a simple aluminum piece for pulling the old studs out, and also used as a guide for tapping the new threads.
Give a shout to Craig Hendrickson on these boards, he may have a few leftover, or know how to get one.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
The point to life isn't necessarilly the decimal.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 02-21-2004, 11:46 PM
Here's how I did it......
But I wouldn't want to do it with the heads on the engine. It's difficult enough to do it right on a set of bare heads.
My wife says I never listen to her, at least that's what I think she said.
