Old 05-25-2005, 07:15 PM
David Jones's Avatar
Congrats on the shroud.
Old 05-25-2005, 07:55 PM
blownb310 blownb310 is offline
Thanks for finding it for me David. I wasn't home to watch the auction. Earlier in the day I bid as high as I cared to go and let the chips fall where they may. I was surprised I won the auction.
I wonder if it will get here in time for this weekend's Hemming's "Musclepalooza" F.A.S.T. race at Lebanon Valley Dragway?
Old 05-26-2005, 12:20 AM
LanceW LanceW is offline
I am also wondering what years of dual snorkels are interchangeable? I have heard that 69 and 70 are the same but previous posts in this thread seem to disagree. I have also heard that all 68-72 dual snorkels are the same. Anyone know?
LanceW
Old 05-26-2005, 06:03 AM
I'm no authority by any stretch, but I believe that there is a difference between the F-body and the A & G-body air cleaners. It had something to do with hood clearance and the depth of the carb flange.
Anyone know what color heat riser hose is correct for the A-body cars in '69? I've seen black and silver hoses. Which one should be there?
Old 05-26-2005, 09:40 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
i do not believe that 69 and 70 are the same.
as mentioned earlier, the angles are different, as would the base over the carb.
i think, starting in 70 on at least the hi-po cars, the carb has a smoke stack like bowl vent, as opposed to the 69's which used the metal strip with a rubber gasket.
the smoke stack equipped cars had air cleaners with a hole for that to fit into.
the 71 and/or 72 may, may have had, an additional thermac switch poking out horizontally from the side. i cannot recall seeing one exactly, on a dual pan, but i have on the single jobs.
costs too much
Old 06-03-2005, 04:20 PM
slowgto slowgto is offline
1969 and 1970 air cleaners are a little different, if you are picky. If you measure between the snorkel intakes you will see the difference.
Old 06-03-2005, 06:38 PM
Very interesting!
